I just installed Nextcloud using snaps in ubuntu. I am new to all this specially to linux. The install went great, but after setting up my local external hard drive with nextcloud I am able to see the external folder but when I open the folder in nextcloud nothing that I have save in the folder showed up I can see it when I open the drive on my computer but on nextcloud I am unable to see the files I had saved. Can some one help? Thanks in advance
I don’t use the Snap package myself, but maybe this is of any help…
https://github.com/nextcloud-snap/nextcloud-snap#removable-media
Thank you for the quick reply. I was able to place the command but still having the same issue
