Been searching on the internet to find post on how connect the hardware after the initial installation of the box and the RPi. I havn’t succeded… Maybe there is an informative link?
My situation is, I use a cable connection for internet (not wireless), like her How to secure (pair) the Powerline Network | TP-Link (including my laptop).
My main idea about the Nextcloud box, is to use it as a separate unit, connected to own power outlet and own internet connection (cabled).
My uncertainty is as follows:
Is it correct to connect the female micro SD (from the 3-connection cable) with the male micro SD leaving a USB male outside the box? This should be connected with the power connection?
Can I connect the cable directly into the RPi? There is ’a hole’ in which an internet cable can fit.
I have tried it but it hasn’t work yet.
Thanks in advance:-).
