I’m having a very specific issue. I finished a new installation of nextcloud 15 (been using 13 so far), and when used from my LAN network I manage to register correctly using my local dns resolver, and also via ip.
Thing is when I try to login the desktop app via WAN, I got a timeout error pointing to my internal IP address.
Apparently when it’s resolving its redirects internally, it points to the LAN address instead of the hostname. I searched on various config files I could find but nothing.
I used the Hansson IT prebuilt appliance before and it didn’t have any issue. When I installed this version the unique problem i’m facing is this one. I cant find anywhere solution to this, any help will be appreciated.
Thank you very much in advance.
