Hello
I am very new to raspberry pi and its possibilities.
I would like to install Home Assistant and Nextcloud on my new raspberry pi 4 using an external SSD drive on USB.
Which solution do you advice to me ?
Install rapsberry pi 4 OS (which one) than Home Assistant and then Nextcloud ?
Or is it better to install directly HAOS and than Nextcloud ?
Do you know a good tutoriel for this installation ?
How to configurate the use of an external drive ?
Thanks a lot for your help
Sullivan
