Hi Everyone,
I am trying to get Nextcloud up and running on Microsoft Azure by following the installation guide on Installation on Linux — Nextcloud 13 Administration Manual 13 documentation.
Special situation: I want the database to be outside of my webserver and to be a Microsoft Azure Managed MySQL instance. This worked fine for me in many other projects. It usually works like any other personal setup mysql database.
I have set up
- an Ubuntu 16.04.5 LTS as OS
- Apache2 as Webserver
- Installed packages are:
- apache2
- libapache2-mod-php7.0
- php7.0-gd
- php7.0-json
- php7.0-mysql
- php7.0-curl
- php7.0-mbstring
- php7.0-intl
- php7.0-mcrypt
- php-imagick
- php7.0-xml
- php7.0-zip
- Apache config in
/etc/apache2/sites-available/nextcloud.conf
looks like:
Alias /nextcloud "/var/www/nextcloud/"
Options +FollowSymlinks
AllowOverride All
<IfModule mod_dav.c>
Dav off
</IfModule>
Satisfy Any
</Directory>
- Syslink is created with
sudo ln -s /etc/apache2/sites-available/nextcloud.conf /etc/apache2/sites-enabled/nextcloud.conf
- Apache is configed like:
sudo a2enmod rewrite
sudo a2enmod headers
sudo a2enmod env
sudo a2enmod dir
sudo a2enmod mime
sudo service apache2 restart
sudo a2enmod ssl
sudo a2ensite default-ssl
sudo service apache2 reload
- Nextcloud was installed with
wget https://download.nextcloud.com/server/releases/nextcloud-13.0.5.tar.bz2
- Extracted and copied into
/var/www/nextcloud
- Giving access rights with
sudo chown -R www-data:www-data /var/www/nextcloud/
- Accessing the Installation Wizard and filling out the data ends in:
- I have provided the following information:
- Administrator:
<myAdminName (all lowercase letters)>
- Administrator-password:
<MyPassword (lowercase, upercase, special chars, numbers)>
- DataDirectory :
/opt/nextcloud
- Database adminstraor:
NOTE that Microsoft Azure depicts the username as<myAdminName>@<hostname> e.g. dbadmin@my-db
- Password:
- Database:
nextcloud
- Host:
<hostname (all lowercase concated with "-")>.mysql.database.azure.com:3306
- Administrator:
- I have disabeld SSL enforcement in the Azure MySQL databse, as this seems to have caused other issues as well
- Connecting to MySQL database from inside the nextcloud webser with
mysql -h <hostname> -u <username> -p
works absolutley flawless.
Can you help me get nextcloud up and running with being connected to the Azure MySQL database?
Any thoughts on the error during the installation?
Best,
erosinger
