I tried several times to install nextcloudpi and the installation never complete.
Procedure:
1.write raspbian lite img on a 4gb sd card
2.put sd in the pi and ssh to it.
3.run command “curl -sSL https://raw.githubusercontent.com/nextcloud/nextcloudpi/master/install.sh | sudo bash”
it always stops here:
System config value trusted_domains => 5 set to string nextcloudpi.local
System config value mail_smtpmode set to string php
System config value mail_smtpauthtype set to string LOGIN
System config value mail_from_address set to string admin
System config value mail_domain set to string ownyourbits.com
Error: Could not download app calendar
pi@raspberrypi:~ $
This line seems to be in nc-init.sh. I looked up and there is a command “sudo -u www-data php /var/www/nextcloud/occ app:install calendar”
when I run this command manually it works and says app calendar installed!
How can I fix this and why doesn’t installation complete after that error?
Thank you in advanced.
