Hi
I have problem to start up my nextcloud box. I connected all the hardware together inserted the sd card with snap but I can not access the pi 2 via internet.
I checked the sd card and it is not empty
how can I resolve it … or at least find out what is wrong
thanx
I get also this error when running
“can’t find nextcloud.local: Non-existent domain” when running nslookup nextcloud.local
So you try to run Nextcloud on a Raspberry pi 2?
The best thing is to start locally. Meaning try to connect a screen/keyboard to the pi 2, and enter the terminal within. You can check if first if apache is running etc.
When you think everything is running ok. You can execute:
arp -a
Look at the IP address next to “b8-27”, that is the IP of your PI.
Now can try to access this from another computer within the same network (LAN).
When everything is working, you can open port 80/443 on your router together with the IP, so it’s accessible from the Internet.
Be-ware to make the IP statically defined within your pi2, otherwise a reboot could cause to get you another IP address. Meaning you need to change your router settings again and again ><…
More info:
