Info.xml problem with require min and require max of ownCloud and Nextcloud version
Hi, I wast just thinking about something.
Currently both Nextcloud and ownCloud use the <owncloud min-version="" max-version=""/> tag inside info.xml. (specific in the dependencies section)
The problem is that an app could support Nextcloud 10 but no necessarily ownCloud 10. (especially since this means a totally different release).
There are multiple solutions for this:
  • introduce a nextcloud tag
  • release two versions of an app
cc @BernhardPosselt for the appstore
EDIT: please note that this isn’t a big problem, just something we have to keep in mind I guess. :smile:
ownCloud 9.1 is Nextcloud 10
ownCloud 9.2 is Nextcloud 11
Afterwards we will have a look at this again.
Until then use the owncloud-tag with the translated number.
The UI will still show “version 10 is required”, since I fixed that recently:
Afaik in nextcloud 10 you can just add
<nextcloud min-version="10"/>
@BernhardPosselt @nickvergessen
Where to add this owncloud-tag with the translated number that the system accept the app?
Does it always work in this format as mentioned: <nextcloud min-version="10"/> ?
I would like to use this at one app if it works at NC 10
Thanks
No, we only check <owncloud min-version="9.1"/> for now (NC 9, NC 10), also see docs:
https://docs.nextcloud.com/server/9/developer_manual/app/info.html#owncloud
