example
longer
example
here
Nextcloud version (eg, 12.0.2): 14.0.3
Operating system and version (eg, Ubuntu 17.04): RHEL 7.5
PHP version (eg, 7.1): 7.2.11
When loglevel is set to 1 in config.php for info, no info level messages are logged. Debug level works, as does warn level, but nothing for info. When set to debug level, there were still no info level messages logged to the nextcloud.log file. We enabled the Auditing / Logging app, which is sending file related messages to the audit.log file correctly, but with user ID instead of user name.
- Installed nextcloud apache version with nginx and mariadb containers, set up with docker-compose file.
- Integrated successfully with Active Directory for authentication.
- Uploaded / deleted files.
Just a few invalid login attempts.
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'oc11g74qrh8r',
'loglevel' => 1,
'passwordsalt' => '<string>',
'secret' => '<string>',
0 => 'nextcloud-app',
'version' => '14.0.3.0',
'overwrite.cli.url' => 'http://nextcloud-app',
'overwritehost' => 'nextcloud.<domain>',
'dbname' => 'nextcloud',
'dbhost' => 'db',
'dbtableprefix' => '',
'dbuser' => 'nextcloud',
'dbpassword' => '<PW>',
'ldapIgnoreNamingRules' => false,
Sample audit.log message with user ID. Can we change this to list username instead of ID????
{"reqId":"NhUGTIJjBYQA6He4dswz","level":1,"time":"2018-11-06T17:58:36+00:00","remoteAddr":"172.17.0.4","user":"8C861345-0B06-4465-989D-FA76C086FF60","app":"admin_audit","method":"PUT","url":"\/remote.php\/webdav\/7160-002.txt","message":"File created: \"\/\/7160-002.txt\"","userAgent":"Mozilla\/5.0 (X11; Linux x86_64; rv:52.0) Gecko\/20100101 Firefox\/52.0","version":"14.0.3.0"}
