Incorrect links in the Tags section
In the “Tags” section, there is a list of existing tags. Normally, clicking a tag should display a list of files and folders associated with it. However, this is currently broken because the generated links are incorrect.
  1. Go to /apps/files/files
  2. Go to Tags link
  3. Click on some tag
Actual URL: /apps/files/files/4?dir=/4 (wrong)
Expected URL: /apps/files/tags/4?dir=/4
Nextcloud Server version: Nextcloud Hub 26 Winter (33.0.0)
Operating system and version: Linux 6.8.0-90-generic x86_64
Web server and version: Apache/2.4.66 (Unix)Reverse proxy and version: nginx/1.24.0
PHP version: PHP 8.3.30
Is this the first time you’ve seen this error? : Yes
When did this problem seem to first start? …
Installation method: Docker AIO
Are you using Cloudflare, mod_security, or similar? : No
Hey @Stanislav_K_Kur welcome to the nextcloud community :waving_hand:
You’ve posted a request in the general section. Unfortunately you have not completed the required support template. So we have no idea which version of Nextcloud you are using. Please edit your post and add as much information as possible so that community supporters have the necessary technical information to help you!
Please be clear if this is a support issue.
Without additional information the community members cannot help you.
Thanks, I have updated my question with the missing data.
@Stanislav_K_Kur thanks for your edit :+1:
added tag aio nc33 and moved to support section, please be patient…
I am on 32.0.6 and it is correct there, for the case that helps.
I’m using nexcloud 33.0.2 and have the same error (not an aio installation)
See issue at [Bug]: Clicking a tag from the tags view in browser does not work · Issue #59410 · nextcloud/server · GitHub
