I noticed there are differences between NC-documentation and NC-installation. For example, server admin manual says “Trusted domains” should be in the form:
0 => 'localhost',
1 => 'server1.example.com',
2 => '192.168.1.50',
3 => '[fe80::1:50]',
But when you download latest NC.zip, extract it and look into ./config/config.sample.php, the same setting is defined as:
'demo.example.org',
'otherdomain.example.org',
'10.111.112.113',
'[2001:db8::1]'
So what is proper and correct way? If both, then there should be some notice about it somewhere.
Something similar for caching. I have seen somewhere:
'memcache.local' => '\OC\Memcache\APCu',
but also:
Both probably mean the same, but still it might be confusing for any new user. I think this inconsistency between documentation and installation should be avoided.
