Nextcloud version: 29.0.4
Chart version: 2.0.11
Operating system and version: TrueNAS Scale 24.04.2
Apache or nginx version: nginx 1.25.4
PHP version: whatever the TrueNAS Community NextCloud app installer set up
I put off updating my TrueNAS server for several months because of OpenVPN being removed. I recently bit the bullet, with the intention of setting up Zerotier as a replacement for Open VPN. I updated TrueNAS Bluefin to Cobia to Dragonfish, and I correspondingly upgraded NextCloud from the originally installed version (27?) to 29.0.4.
The upgrades proceeded successfully and TrueNAS has NextCloud flagged as Running. It is using a nominal amount of CPU and maybe 66MiB of RAM, and is actively using a few kb/s of network traffic.
Since the upgrade, when I click Web Portal in Apps > Nexcloud > Application Info I get a persistent Maintenance mode window.
Is this the first time you’ve seen this error?: Y
- I don’t have another TrueNAS system lying around in order to figure out if this can be replicated and what steps might be required to do so
I suspect the requests below are not optimised for a TrueNAS installation
I'd love to provide this but there is no logging apparent to me from the TrueNAS Apps > NextCloud app page, and when I click on Web Portal to access NextCloud to find Admin > Logging I get a Maintenance mode window
When I open the shell in TrueNAS and cd to /mnt/tank/nextcloud I get a permission denied error, though this is the admin@truenas$ shell
there is no subfolder called '____' in /var/log on my TrueNAS box
there is no /var/www/nextcloud.log on my TrueNAS box and I cannot access the Nextcloud portal to access the admin menu because of the maintenance mode
I can provide the following History from the TrueNAS Applications window:
2024-07-25 19:00:12
Job completed
2024-07-25 19:00:12
Saw completed job: nextcloud-nextcloud-cron-28698180, status: Complete
2024-07-25 19:00:02
Created container nextcloud
2024-07-25 19:00:02
Started container nextcloud
2024-07-25 19:00:00
Created job nextcloud-nextcloud-cron-28698180
2024-07-25 19:00:00
Created pod: nextcloud-nextcloud-cron-28698180-9db9q
2024-07-25 19:00:00
Successfully assigned ix-nextcloud/nextcloud-nextcloud-cron-28698180-9db9q to ix-truenas
2024-07-25 19:00:00
Add eth0 [172.16.5.52/16] from ix-net
2024-07-25 19:00:00
Container image "nextcloud:29.0.4" already present on machine
2024-07-25 18:45:12
Job completed
2024-07-25 18:45:12
Saw completed job: nextcloud-nextcloud-cron-28698165, status: Complete
2024-07-25 18:45:02
2024-07-25 18:45:01
2024-07-25 18:45:00
Created job nextcloud-nextcloud-cron-28698165
2024-07-25 18:45:00
Created pod: nextcloud-nextcloud-cron-28698165-nsqnp
2024-07-25 18:45:00
Successfully assigned ix-nextcloud/nextcloud-nextcloud-cron-28698165-nsqnp to ix-truenas
2024-07-25 18:45:00
Add eth0 [172.16.5.51/16] from ix-net
2024-07-25 18:45:00
2024-07-25 18:30:10
Saw completed job: nextcloud-nextcloud-cron-28698150, status: Complete
2024-07-25 18:30:10
Job completed
2024-07-25 18:30:01
2024-07-25 18:30:01
2024-07-25 18:30:00
Created job nextcloud-nextcloud-cron-28698150
2024-07-25 18:30:00
Created pod: nextcloud-nextcloud-cron-28698150-bcsmv
2024-07-25 18:30:00
Successfully assigned ix-nextcloud/nextcloud-nextcloud-cron-28698150-bcsmv to ix-truenas
2024-07-25 18:30:00
Add eth0 [172.16.5.50/16] from ix-net
2024-07-25 18:30:00
2024-07-25 18:15:09
Job completed
2024-07-25 18:15:09
Saw completed job: nextcloud-nextcloud-cron-28698135, status: Complete
2024-07-25 18:15:02
2024-07-25 18:15:01
2024-07-25 18:15:00
Created job nextcloud-nextcloud-cron-28698135
2024-07-25 18:15:00
Created pod: nextcloud-nextcloud-cron-28698135-qrsrk
2024-07-25 18:15:00
Successfully assigned ix-nextcloud/nextcloud-nextcloud-cron-28698135-qrsrk to ix-truenas
2024-07-25 18:15:00
Add eth0 [172.16.5.49/16] from ix-net
2024-07-25 18:15:00
Under Workloads I see the following:
Docker: Accelerated Container Application Development
with the logs:
2024-07-25 16:47:51.358888+12:00e[38;5;6mredis e[38;5;5m04:47:51.35 e[0m
2024-07-25 16:47:51.360318+12:00e[38;5;6mredis e[38;5;5m04:47:51.35 e[0me[1mWelcome to the Bitnami redis containere[0m
2024-07-25 16:47:51.361797+12:00e[38;5;6mredis e[38;5;5m04:47:51.36 e[0mSubscribe to project updates by watching e[1mhttps://github.com/bitnami/containerse[0m
2024-07-25 16:47:51.364573+12:00e[38;5;6mredis e[38;5;5m04:47:51.36 e[0mSubmit issues and feature requests at e[1mhttps://github.com/bitnami/containers/issuese[0m
2024-07-25 16:47:51.366279+12:00e[38;5;6mredis e[38;5;5m04:47:51.36 e[0m
2024-07-25 16:47:51.370834+12:00e[38;5;6mredis e[38;5;5m04:47:51.36 e[0me[38;5;2mINFO e[0m ==> ** Starting Redis setup **
2024-07-25 16:47:51.593833+12:00e[38;5;6mredis e[38;5;5m04:47:51.59 e[0me[38;5;2mINFO e[0m ==> Initializing Redis
2024-07-25 16:47:51.628621+12:00e[38;5;6mredis e[38;5;5m04:47:51.62 e[0me[38;5;2mINFO e[0m ==> Setting Redis config file
2024-07-25 16:47:52.363143+12:00e[38;5;6mredis e[38;5;5m04:47:52.35 e[0me[38;5;2mINFO e[0m ==> ** Redis setup finished! **
2024-07-25 16:47:52.363262+12:002024-07-25T16:47:52.363262292+12:00
2024-07-25 16:47:52.381826+12:00e[38;5;6mredis e[38;5;5m04:47:52.38 e[0me[38;5;2mINFO e[0m ==> ** Starting Redis **
2024-07-25 16:47:52.566463+12:001:C 25 Jul 2024 04:47:52.566 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
2024-07-25 16:47:52.566536+12:001:C 25 Jul 2024 04:47:52.566 # Redis version=7.0.11, bits=64, commit=00000000, modified=0, pid=1, just started
2024-07-25 16:47:52.566566+12:001:C 25 Jul 2024 04:47:52.566 # Configuration loaded
2024-07-25 16:47:52.568217+12:001:M 25 Jul 2024 04:47:52.568 * monotonic clock: POSIX clock_gettime
2024-07-25 16:47:52.591891+12:001:M 25 Jul 2024 04:47:52.591 * Running mode=standalone, port=6379.
2024-07-25 16:47:52.591932+12:001:M 25 Jul 2024 04:47:52.591 # Server initialized
2024-07-25 16:47:52.641226+12:001:M 25 Jul 2024 04:47:52.641 * Creating AOF base file appendonly.aof.1.base.rdb on server start
2024-07-25 16:47:52.727188+12:001:M 25 Jul 2024 04:47:52.726 * Creating AOF incr file appendonly.aof.1.incr.aof on server start
2024-07-25 16:47:52.727811+12:001:M 25 Jul 2024 04:47:52.726 * Ready to accept connections
docker.io/library/nextcloud:29.0.4
with the logs:
2024-07-25 16:47:51.082935+12:002024-07-25T16:47:51.082935847+12:00
2024-07-25 16:47:51.083013+12:00PostgreSQL Database directory appears to contain a database; Skipping initialization
2024-07-25 16:47:51.083026+12:002024-07-25T16:47:51.083026409+12:00
2024-07-25 16:47:52.506503+12:002024-07-25 04:47:52.506 UTC [1] LOG: starting PostgreSQL 13.1 (Debian 13.1-1.pgdg100+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.3.0-6) 8.3.0, 64-bit
2024-07-25 16:47:52.507105+12:002024-07-25 04:47:52.506 UTC [1] LOG: listening on IPv4 address "0.0.0.0", port 5432
2024-07-25 16:47:52.507443+12:002024-07-25 04:47:52.506 UTC [1] LOG: listening on IPv6 address "::", port 5432
2024-07-25 16:47:52.583403+12:002024-07-25 04:47:52.583 UTC [1] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-07-25 16:47:52.723775+12:002024-07-25 04:47:52.723 UTC [13] LOG: database system was shut down at 2024-07-25 04:47:40 UTC
2024-07-25 16:47:52.807488+12:002024-07-25 04:47:52.807 UTC [1] LOG: database system is ready to accept connections
docker.io/library/nginx:1.25.4
with the logs: (just a taste)
2024-07-25 19:23:31.375682+12:00172.16.0.1 - - [25/Jul/2024:07:23:31 +0000] "GET /status.php HTTP/2.0" 200 168 "-" "kube-probe/1.26"
2024-07-25 19:23:38.043034+12:00192.168.178.49 - jeremy [25/Jul/2024:07:23:38 +0000] "GET /index.php/204 HTTP/1.1" 503 12310 "-" "Mozilla/5.0 (Windows) mirall/3.13.0stable-Win64 (build 20240423) (Nextcloud, windows-10.0.22631 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
2024-07-25 19:23:38.067335+12:00192.168.178.49 - jeremy [25/Jul/2024:07:23:38 +0000] "GET /status.php HTTP/1.1" 200 168 "-" "Mozilla/5.0 (Windows) mirall/3.13.0stable-Win64 (build 20240423) (Nextcloud, windows-10.0.22631 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
2024-07-25 19:23:41.375165+12:00172.16.0.1 - - [25/Jul/2024:07:23:41 +0000] "GET /status.php HTTP/2.0" 200 168 "-" "kube-probe/1.26"
2024-07-25 19:23:41.375468+12:00172.16.0.1 - - [25/Jul/2024:07:23:41 +0000] "GET /status.php HTTP/2.0" 200 168 "-" "kube-probe/1.26"
2024-07-25 19:23:51.375269+12:00172.16.0.1 - - [25/Jul/2024:07:23:51 +0000] "GET /status.php HTTP/2.0" 200 168 "-" "kube-probe/1.26"
2024-07-25 19:23:51.375498+12:00172.16.0.1 - - [25/Jul/2024:07:23:51 +0000] "GET /status.php HTTP/2.0" 200 168 "-" "kube-probe/1.26"
2024-07-25 19:24:01.375718+12:00172.16.0.1 - - [25/Jul/2024:07:24:01 +0000] "GET /status.php HTTP/2.0" 200 168 "-" "kube-probe/1.26"
2024-07-25 19:24:01.375781+12:00172.16.0.1 - - [25/Jul/2024:07:24:01 +0000] "GET /status.php HTTP/2.0" 200 168 "-" "kube-probe/1.26"
docker.io/library/postgres:13.1
with the logs:
