Nextcloud version (eg, 10.0.3):
Operating system and version (eg, Rasbian ):
Apache (eg, Apache 2.4.25):
PHP version (eg, 7.0):
Is this the first time you’ve seen this error?: YES
Can you reliably replicate it? (If so, please outline steps): YES
Dear everyone,
When I try to change something in my administration section, nextcloud ask me for my password. I enter the password and after few second nextcloud ask me again for my password.
I try to change my information exemple credentials for the mail systeme, but everytime nextcloud ask me for my password. My password is ok because I can logging in nextcloud.
Warning core Trusted domain error. “127.0.0.1” tried to access using “88.185.116.54” as host. 4 hours ago
Warning no app in context Missing expected parameters in change user hook 5 hours ago
Warning core Login failed: ‘baimard’ (Remote IP: ‘127.0.0.1’) 5 hours ago
Warning core Login failed: ‘baimard’ (Remote IP: ‘127.0.0.1’) 6 hours ago
‘instanceid’ => ‘’,
‘passwordsalt’ => ‘’,
‘secret’ => ‘+’,
‘trusted_domains’ =>
0 => ‘192.168.0.240’,
1 => ‘baim.freeboxos.fr’,
‘datadirectory’ => ‘’,
‘overwrite.cli.url’ => ‘https://192.168.0.240’,
‘dbtype’ => ‘mysql’,
‘version’ => ‘11.0.3.2’,
‘dbname’ => ‘nextcloud’,
‘dbhost’ => ‘localhost’,
‘dbport’ => ‘’,
‘dbtableprefix’ => ‘oc_’,
‘dbuser’ => ‘oc_baimard’,
‘dbpassword’ => ‘’,
‘logtimezone’ => ‘UTC’,
‘installed’ => true,
‘maintenance’ => false,
[Thu May 04 16:52:32.883526 2017] [authz_core:error] [pid 31437] [client 127.0.0.1:44482] AH01630: client denied by server configuration: /mnt/nextcloud/cloud/data/.ocdata
[Thu May 04 16:55:32.664401 2017] [authz_core:error] [pid 32414] [client 127.0.0.1:44634] AH01630: client denied by server configuration: /mnt/nextcloud/cloud/data/.ocdata
[Thu May 04 16:57:07.159300 2017] [authz_core:error] [pid 32725] [client 127.0.0.1:44734] AH01630: client denied by server configuration: /mnt/nextcloud/cloud/data/.ocdata
[Thu May 04 16:57:12.063378 2017] [authz_core:error] [pid 32701] [client 127.0.0.1:44748] AH01630: client denied by server configuration: /mnt/nextcloud/cloud/data/.ocdata
[Thu May 04 16:58:04.793473 2017] [authz_core:error] [pid 32701] [client 127.0.0.1:44802] AH01630: client denied by server configuration: /mnt/nextcloud/cloud/data/.ocdata
[Thu May 04 17:05:41.433463 2017] [authz_core:error] [pid 389] [client 127.0.0.1:45016] AH01630: client denied by server configuration: /mnt/nextcloud/cloud/data/.ocdata
[Thu May 04 17:07:39.845348 2017] [authz_core:error] [pid 461] [client 127.0.0.1:45076] AH01630: client denied by server configuration: /mnt/nextcloud/cloud/data/.ocdata
[Thu May 04 17:12:51.423395 2017] [authz_core:error] [pid 32664] [client 127.0.0.1:45140] AH01630: client denied by server configuration: /mnt/nextcloud/cloud/data/.ocdata
[Thu May 04 21:20:54.733442 2017] [authz_core:error] [pid 1566] [client 127.0.0.1:45488] AH01630: client denied by server configuration: /mnt/nextcloud/cloud/data/.ocdata
[Thu May 04 21:20:59.533420 2017] [authz_core:error] [pid 1319] [client 127.0.0.1:45500] AH01630: client denied by server configuration: /mnt/nextcloud/cloud/data/.ocdata
Tks everyone
