Hello fellows,
I have a snap nextcloud installed on an ODROID-H2+ running on an Ubuntu 20.04.1 LTS.
Initially I installed an SSL certificate with Let’s Encrypt.
This allowed me to use nextcloud inside my LAN via HTTP and through the internet via HTTPS.
However, I don’t want to have two instances of the connection in my android phone. I just want that the HTTPS connection via my DDNS is posible.
I added the DNS entry in my home router so that the DDNS host points to the nextcloud IP.
I can’t log in nextcloud via android app or via browser with any device inside the LAN.
The error I get is: ERR_CONNECTION_TIMED_OUT
The output the config.php:
GNU nano 4.8 config.php
'apps_paths' =>
0 =>
'path' => '/snap/nextcloud/current/htdocs/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/var/snap/nextcloud/current/nextcloud/extra-apps',
'url' => '/extra-apps',
'writable' => true,
'supportedDatabases' =>
0 => 'mysql',
'redis' =>
'host' => '/tmp/sockets/redis.sock',
'port' => 0,
'passwordsalt' => 'SECRET',
'secret' => 'SECRET',
0 => 'localhost',
1 => 'somesubdomain.duckdns.org',
2 => '192.168.YY.XX',
'datadirectory' => '/var/snap/nextcloud/common/nextcloud/data',
'version' => '20.0.2.2',
'overwrite.cli.url' => 'https://somesubdomain.duckdns.org',
'overwritehost' => 'somesubdomain.duckdns.org',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:/tmp/sockets/mysql.sock',
'dbuser' => 'nextcloud',
'dbpassword' => 'SECRET',
'instanceid' => 'SECRET',
'loglevel' => 2,
