English version
Good morning all,
I come to see you because I have just configured my nextcloud instance with the javascript xmpp application.
This one seems to work well, I am correctly connected to my bosh server but for some reason I am constantly forced to enter my xmpp credentials when I connect to nextcloud, it does not save them so the user is disconnected and the chat functions do not work logically.
I also have a CSRF check failed nextcloud error when I want to disconnect while the session has remained active for too long, I don’t know if it can be linked.
Is also when I want to send an attachment via the xmpp it tells me this:
Error: The download was probably blocked by your browser. The attachment was not processed
The only errors on apache are these:
[proxy_http:error] [pid 800323] (70014)End of file found: [client xxxxx:51702] AH01102: Error reading remote server status line 127.0.0.1:5443
[Wed Apr 06 13:33:28.242669 2022] [proxy:error] [pid 800323] [client xxxxxx:51702] AH00898: Error reading from remote server returned by /http-bind
But I don’t know if it could be related
Have you ever encountered one of these two errors? Thanks in advance everyone
Cordially
Version Française :
Bonjour à tous,
Je viens vous voir car je viens de configurer mon instance nextcloud avec l’application javascript xmpp.
Celle ci a l’air de bien fonctionner ai est correctement relié à mon serveur bosh mais pour une raison que j’ignore je suis sans cesse obligé de rentrer mes identifiants xmpp quand je me connecte sur nextcloud, il ne les garde pas en mémoire donc l’user et déconnecté et les fonctions du chat ne fonctionnement logiquement pas.
J’ai aussi une erreur CSRF check failed nextcloud lorsque je souhaite me déconnecter alors que la session est resté trop longtemps active, je ne sais pas si ça peut être liée.
Et dernière chose, quand j’essaie d’envoyer une pièce jointe via le chat xmpp il me dit ceci :
Error: Upload was probably blocked by your browser. Attachment was not processed
Les seules erreurs sur apache que j’ai trouvé sont celles ci :
[proxy_http:error] [pid 800323] (70014)End of file found: [client xxxxxx:51702] AH01102: error reading status line from remote server 127.0.0.1:5443
Mais j’ignore si ça peut être liée
Avez vous déjà rencontré l’une de ces deux erreurs ? Merci d’avance à tous
Cordialement
