Nextcloud version (eg, 20.0.5): 24.0.1
Operating system and version (eg, Ubuntu 20.04): Raspberry Pi Buster / Linux raspberrypi 5.10.103-v7l+
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.38 (Raspbian)
PHP version (eg, 7.4): 7.4-fpm
The icons in the System section under Settings are broken and the chart boxes are empty. See the image attached. It used to work ok and then the issue just appeared.
- Go to Settings
- go to System
Restarted Apache, the system. Still the same.
https://imgur.com/VWrr0y4
Thanks,
Adrian
