Hello
I am a new nextcloud home user. I have problems with storage space? The disk space is 1.5 TB, but Nextcloud reports that the space is only 81.5 GB? Nextcloud is installed on Ubuntu server 22.04 version and Nextcloud version is 24.0.3. In the user settings, I have set the default to 1 TB. Can you please help?
Thank you
Mostly the user have configured the datadirectory
on the wrong partition.
Search in config/config.php
'datadirectory' => '/path/to/nextcloud/data',
Please post this entry and post details of your partitions.
You can move the datadirectory
to another path/partition if needed.
Thank you for your answer. I believe I can get it resolved.
The Nextcloud installation comes automatically, in the installation of the Ubuntu server, if you wish. It cannot be influenced by which directory the data partition goes into
regards
Really. Or do you use Snap? Then search Nextcloud Snap installation
I use this installation guide for Ubuntu 22.04 LTS without Snap.
Yes, that would be the rather inflexible snap installation. Itβs in a list of available packages during Ubuntu Server setup.
Personally I would not recommend this method.
