I have a question about authority management
hi there
if i have admin authority ,can i check all users folder ?or have some configuration ?
If you have access to the file system at the operating system level and the files are not encrypted, you can see all the files there.
With the → Impersonate - impersonate app, you as an administrator can impersonate any user and tweak the nodes as if you were the user himselve.
Hope this helps,
much luck!
