Hundreds of Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon" entries after Update to NC30
    • Nextcloud Hub 9 (30.0.5)
    • Ubuntu 22.04
    • nginx 1.18.0
    • 1.12.2
    • 8.1
    • Yes
    • Upon updating to nextcloud 30
Seeing hundreds of log entries all complaining about “Calling OCP\DB\QueryBuilder\IQueryBuilder::orX without parameters is deprecated and will throw soon”
"reqId":"EwCH6SYT4lh5wcgC8kyy","level":0,"time":"2025-02-18T10:58:13+00:00","remoteAddr":"192.168.11.1","user":"dmcgraw","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/username/SSEH/Admin/Staff%20Folders/Huw%20SSEH/%231%20SPWT/AeroSensor/SSEH/P0024/S0002/R0005/E0021","message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","userAgent":"Mozilla/5.0 (Windows) mirall/3.2.1stable-Win64 (build 20210428) (Nextcloud, windows-10.0.22631 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"30.0.5.1","exception":{"Exception":"Exception","Message":"No parameters in call to OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder::orX","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1203,"function":"orX","class":"OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1121,"function":"leftJoinInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/CirclesQueryHelper.php","line":130,"function":"limitToInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":689,"function":"limitToInheritedMembers","class":"OCA\\Circles\\CirclesQueryHelper","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":932,"function":"getFoldersFromCircleMemberships","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":111,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":115,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":72,"function":"getMountsForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":85,"function":"getMountsFromProvider","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"function":"OC\\Files\\Config\\{closure}","class":"OC\\Files\\Config\\MountProviderCollection","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":84,"function":"array_map"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":102,"function":"getUserMountsForProviders","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":413,"function":"getUserMountsForProviderClasses","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Mount/Manager.php","line":75,"function":"setupForPath","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1344,"function":"find","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":177,"function":"getFileInfo","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php","line":95,"function":"getChild","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":971,"function":"getNodeForPath","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1662,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1647,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":146,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/DB/QueryBuilder/ExpressionBuilder/ExpressionBuilder.php","Line":87,"message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","exception":{},"CustomMessage":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon."}}
{"reqId":"WkaBWdgoAFjxgaUmRqm6","level":0,"time":"2025-02-18T11:15:38+00:00","remoteAddr":"192.168.11.1","user":"aholmes","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/aholmes/","message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","userAgent":"Mozilla/5.0 (Windows) mirall/3.15.3 (build 20250107) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"30.0.5.1","exception":{"Exception":"Exception","Message":"No parameters in call to OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder::orX","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1203,"function":"orX","class":"OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1121,"function":"leftJoinInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/CirclesQueryHelper.php","line":130,"function":"limitToInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":689,"function":"limitToInheritedMembers","class":"OCA\\Circles\\CirclesQueryHelper","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":932,"function":"getFoldersFromCircleMemberships","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":111,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":115,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":72,"function":"getMountsForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":121,"function":"getMountsFromProvider","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":207,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":306,"function":"OC\\Files\\{closure}","class":"OC\\Files\\SetupManager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":208,"function":"setupForUserWith","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":386,"function":"setupForUser","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Mount/Manager.php","line":117,"function":"setupForPath","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1393,"function":"findIn","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":94,"function":"addSubMounts","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":202,"function":"getFileInfo","class":"OC\\Files\\Node\\Node","type":"->"},{"function":"getMTime","class":"OC\\Files\\Node\\Node","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":64,"function":"call_user_func_array"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":220,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Node.php","line":152,"function":"getMTime","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":749,"function":"getLastModified","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/PropFind.php","line":95,"function":"Sabre\\DAV\\{closure}","class":"Sabre\\DAV\\CorePlugin","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":753,"function":"handle","class":"Sabre\\DAV\\PropFind","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"propFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1662,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1647,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":146,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/DB/QueryBuilder/ExpressionBuilder/ExpressionBuilder.php","Line":87,"message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","exception":{},"CustomMessage":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon."}}
{"reqId":"HPYEDlIJNTT0PbuhlLOg","level":0,"time":"2025-02-18T11:18:11+00:00","remoteAddr":"192.168.11.1","user":"mariokillar","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/mariokillar/","message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","userAgent":"Mozilla/5.0 (Windows) mirall/3.15.3 (build 20250107) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"30.0.5.1","exception":{"Exception":"Exception","Message":"No parameters in call to OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder::orX","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1203,"function":"orX","class":"OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1121,"function":"leftJoinInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/CirclesQueryHelper.php","line":130,"function":"limitToInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":689,"function":"limitToInheritedMembers","class":"OCA\\Circles\\CirclesQueryHelper","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":932,"function":"getFoldersFromCircleMemberships","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":111,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":115,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":72,"function":"getMountsForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":121,"function":"getMountsFromProvider","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":207,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":306,"function":"OC\\Files\\{closure}","class":"OC\\Files\\SetupManager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":208,"function":"setupForUserWith","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":386,"function":"setupForUser","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Mount/Manager.php","line":117,"function":"setupForPath","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1393,"function":"findIn","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":94,"function":"addSubMounts","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":221,"function":"getFileInfo","class":"OC\\Files\\Node\\Node","type":"->"},{"function":"getEtag","class":"OC\\Files\\Node\\Node","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":64,"function":"call_user_func_array"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":240,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Node.php","line":182,"function":"getEtag","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/FilesPlugin.php","line":345,"function":"getETag","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/PropFind.php","line":95,"function":"OCA\\DAV\\Connector\\Sabre\\{closure}","class":"OCA\\DAV\\Connector\\Sabre\\FilesPlugin","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/FilesPlugin.php","line":346,"function":"handle","class":"Sabre\\DAV\\PropFind","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"handleGetProperties","class":"OCA\\DAV\\Connector\\Sabre\\FilesPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1662,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1647,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":146,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/DB/QueryBuilder/ExpressionBuilder/ExpressionBuilder.php","Line":87,"message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","exception":{},"CustomMessage":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon."}}
{"reqId":"Buh4LnjOfEGxNZo0HQu7","level":0,"time":"2025-02-18T11:27:18+00:00","remoteAddr":"192.168.11.1","user":"mariokillar","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/mariokillar/","message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","userAgent":"Mozilla/5.0 (Windows) mirall/3.15.3 (build 20250107) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"30.0.5.1","exception":{"Exception":"Exception","Message":"No parameters in call to OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder::orX","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1203,"function":"orX","class":"OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1121,"function":"leftJoinInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/CirclesQueryHelper.php","line":130,"function":"limitToInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":689,"function":"limitToInheritedMembers","class":"OCA\\Circles\\CirclesQueryHelper","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":932,"function":"getFoldersFromCircleMemberships","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":111,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":115,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":72,"function":"getMountsForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":121,"function":"getMountsFromProvider","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":207,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":306,"function":"OC\\Files\\{closure}","class":"OC\\Files\\SetupManager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":208,"function":"setupForUserWith","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":386,"function":"setupForUser","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Mount/Manager.php","line":117,"function":"setupForPath","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1393,"function":"findIn","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":94,"function":"addSubMounts","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":202,"function":"getFileInfo","class":"OC\\Files\\Node\\Node","type":"->"},{"function":"getMTime","class":"OC\\Files\\Node\\Node","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":64,"function":"call_user_func_array"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":220,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Node.php","line":152,"function":"getMTime","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":749,"function":"getLastModified","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/PropFind.php","line":95,"function":"Sabre\\DAV\\{closure}","class":"Sabre\\DAV\\CorePlugin","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":753,"function":"handle","class":"Sabre\\DAV\\PropFind","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"propFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1662,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1647,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":146,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/DB/QueryBuilder/ExpressionBuilder/ExpressionBuilder.php","Line":87,"message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","exception":{},"CustomMessage":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon."}}
{"reqId":"QuL4aBkJNBsXUhkiMBop","level":0,"time":"2025-02-18T11:27:41+00:00","remoteAddr":"192.168.11.1","user":"mariokillar","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/mariokillar/","message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","userAgent":"Mozilla/5.0 (Windows) mirall/3.15.3 (build 20250107) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"30.0.5.1","exception":{"Exception":"Exception","Message":"No parameters in call to OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder::orX","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1203,"function":"orX","class":"OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1121,"function":"leftJoinInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/CirclesQueryHelper.php","line":130,"function":"limitToInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":689,"function":"limitToInheritedMembers","class":"OCA\\Circles\\CirclesQueryHelper","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":932,"function":"getFoldersFromCircleMemberships","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":111,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":115,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":72,"function":"getMountsForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":121,"function":"getMountsFromProvider","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":207,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":306,"function":"OC\\Files\\{closure}","class":"OC\\Files\\SetupManager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":208,"function":"setupForUserWith","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":386,"function":"setupForUser","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Mount/Manager.php","line":117,"function":"setupForPath","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1393,"function":"findIn","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":94,"function":"addSubMounts","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":221,"function":"getFileInfo","class":"OC\\Files\\Node\\Node","type":"->"},{"function":"getEtag","class":"OC\\Files\\Node\\Node","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":64,"function":"call_user_func_array"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":240,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Node.php","line":182,"function":"getEtag","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/FilesPlugin.php","line":345,"function":"getETag","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/PropFind.php","line":95,"function":"OCA\\DAV\\Connector\\Sabre\\{closure}","class":"OCA\\DAV\\Connector\\Sabre\\FilesPlugin","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/FilesPlugin.php","line":346,"function":"handle","class":"Sabre\\DAV\\PropFind","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"handleGetProperties","class":"OCA\\DAV\\Connector\\Sabre\\FilesPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1662,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1647,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":146,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/DB/QueryBuilder/ExpressionBuilder/ExpressionBuilder.php","Line":87,"message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","exception":{},"CustomMessage":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon."}}
{"reqId":"jLsZedfngqk7Lm8Qho1n","level":0,"time":"2025-02-18T11:28:11+00:00","remoteAddr":"192.168.11.1","user":"mariokillar","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/mariokillar/","message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","userAgent":"Mozilla/5.0 (Windows) mirall/3.15.3 (build 20250107) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"30.0.5.1","exception":{"Exception":"Exception","Message":"No parameters in call to OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder::orX","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1203,"function":"orX","class":"OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1121,"function":"leftJoinInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/CirclesQueryHelper.php","line":130,"function":"limitToInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":689,"function":"limitToInheritedMembers","class":"OCA\\Circles\\CirclesQueryHelper","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":932,"function":"getFoldersFromCircleMemberships","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":111,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":115,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":72,"function":"getMountsForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":121,"function":"getMountsFromProvider","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":207,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":306,"function":"OC\\Files\\{closure}","class":"OC\\Files\\SetupManager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":208,"function":"setupForUserWith","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":386,"function":"setupForUser","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Mount/Manager.php","line":117,"function":"setupForPath","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1393,"function":"findIn","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":94,"function":"addSubMounts","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":221,"function":"getFileInfo","class":"OC\\Files\\Node\\Node","type":"->"},{"function":"getEtag","class":"OC\\Files\\Node\\Node","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":64,"function":"call_user_func_array"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":240,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Node.php","line":182,"function":"getEtag","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/FilesPlugin.php","line":345,"function":"getETag","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/PropFind.php","line":95,"function":"OCA\\DAV\\Connector\\Sabre\\{closure}","class":"OCA\\DAV\\Connector\\Sabre\\FilesPlugin","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/FilesPlugin.php","line":346,"function":"handle","class":"Sabre\\DAV\\PropFind","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"handleGetProperties","class":"OCA\\DAV\\Connector\\Sabre\\FilesPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1662,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1647,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":146,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/DB/QueryBuilder/ExpressionBuilder/ExpressionBuilder.php","Line":87,"message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","exception":{},"CustomMessage":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon."}}
{"reqId":"l6GSRXTws8tXaZ2m1Ttj","level":0,"time":"2025-02-18T11:28:20+00:00","remoteAddr":"192.168.11.1","user":"mariokillar","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/mariokillar/","message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","userAgent":"Mozilla/5.0 (Windows) mirall/3.15.3 (build 20250107) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"30.0.5.1","exception":{"Exception":"Exception","Message":"No parameters in call to OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder::orX","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1203,"function":"orX","class":"OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1121,"function":"leftJoinInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/CirclesQueryHelper.php","line":130,"function":"limitToInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":689,"function":"limitToInheritedMembers","class":"OCA\\Circles\\CirclesQueryHelper","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":932,"function":"getFoldersFromCircleMemberships","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":111,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":115,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":72,"function":"getMountsForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":121,"function":"getMountsFromProvider","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":207,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":306,"function":"OC\\Files\\{closure}","class":"OC\\Files\\SetupManager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":208,"function":"setupForUserWith","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":386,"function":"setupForUser","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Mount/Manager.php","line":117,"function":"setupForPath","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1393,"function":"findIn","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":94,"function":"addSubMounts","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":202,"function":"getFileInfo","class":"OC\\Files\\Node\\Node","type":"->"},{"function":"getMTime","class":"OC\\Files\\Node\\Node","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":64,"function":"call_user_func_array"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":220,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Node.php","line":152,"function":"getMTime","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":749,"function":"getLastModified","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/PropFind.php","line":95,"function":"Sabre\\DAV\\{closure}","class":"Sabre\\DAV\\CorePlugin","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":753,"function":"handle","class":"Sabre\\DAV\\PropFind","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"propFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1662,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1647,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":146,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/DB/QueryBuilder/ExpressionBuilder/ExpressionBuilder.php","Line":87,"message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","exception":{},"CustomMessage":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon."}}
{"reqId":"I9W5JUvz9xxe6ZFpD69W","level":0,"time":"2025-02-18T11:28:41+00:00","remoteAddr":"192.168.11.1","user":"mariokillar","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/mariokillar/","message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","userAgent":"Mozilla/5.0 (Windows) mirall/3.15.3 (build 20250107) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"30.0.5.1","exception":{"Exception":"Exception","Message":"No parameters in call to OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder::orX","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1203,"function":"orX","class":"OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1121,"function":"leftJoinInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/CirclesQueryHelper.php","line":130,"function":"limitToInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":689,"function":"limitToInheritedMembers","class":"OCA\\Circles\\CirclesQueryHelper","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":932,"function":"getFoldersFromCircleMemberships","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":111,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":115,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":72,"function":"getMountsForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":121,"function":"getMountsFromProvider","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":207,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":306,"function":"OC\\Files\\{closure}","class":"OC\\Files\\SetupManager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":208,"function":"setupForUserWith","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":386,"function":"setupForUser","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Mount/Manager.php","line":117,"function":"setupForPath","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1393,"function":"findIn","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":94,"function":"addSubMounts","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":221,"function":"getFileInfo","class":"OC\\Files\\Node\\Node","type":"->"},{"function":"getEtag","class":"OC\\Files\\Node\\Node","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":64,"function":"call_user_func_array"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":240,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Node.php","line":182,"function":"getEtag","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/FilesPlugin.php","line":345,"function":"getETag","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/PropFind.php","line":95,"function":"OCA\\DAV\\Connector\\Sabre\\{closure}","class":"OCA\\DAV\\Connector\\Sabre\\FilesPlugin","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/FilesPlugin.php","line":346,"function":"handle","class":"Sabre\\DAV\\PropFind","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"handleGetProperties","class":"OCA\\DAV\\Connector\\Sabre\\FilesPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1662,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1647,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":146,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/DB/QueryBuilder/ExpressionBuilder/ExpressionBuilder.php","Line":87,"message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","exception":{},"CustomMessage":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon."}}
{"reqId":"gjbcTSF2JNvmErn2U15Q","level":0,"time":"2025-02-18T11:29:11+00:00","remoteAddr":"192.168.11.1","user":"mariokillar","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/mariokillar/","message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","userAgent":"Mozilla/5.0 (Windows) mirall/3.15.3 (build 20250107) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"30.0.5.1","exception":{"Exception":"Exception","Message":"No parameters in call to OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder::orX","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1203,"function":"orX","class":"OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/Db/CoreQueryBuilder.php","line":1121,"function":"leftJoinInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/circles/lib/CirclesQueryHelper.php","line":130,"function":"limitToInitiator","class":"OCA\\Circles\\Db\\CoreQueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":689,"function":"limitToInheritedMembers","class":"OCA\\Circles\\CirclesQueryHelper","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php","line":932,"function":"getFoldersFromCircleMemberships","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":111,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Folder\\FolderManager","type":"->"},{"file":"/var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php","line":115,"function":"getFoldersForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":72,"function":"getMountsForUser","class":"OCA\\GroupFolders\\Mount\\MountProvider","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":121,"function":"getMountsFromProvider","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":207,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":306,"function":"OC\\Files\\{closure}","class":"OC\\Files\\SetupManager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":208,"function":"setupForUserWith","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/SetupManager.php","line":386,"function":"setupForUser","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Mount/Manager.php","line":117,"function":"setupForPath","class":"OC\\Files\\SetupManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/View.php","line":1393,"function":"findIn","class":"OC\\Files\\Mount\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":94,"function":"addSubMounts","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/Node.php","line":221,"function":"getFileInfo","class":"OC\\Files\\Node\\Node","type":"->"},{"function":"getEtag","class":"OC\\Files\\Node\\Node","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":64,"function":"call_user_func_array"},{"file":"/var/www/nextcloud/lib/private/Files/Node/LazyFolder.php","line":240,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Node.php","line":182,"function":"getEtag","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/FilesPlugin.php","line":345,"function":"getETag","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/PropFind.php","line":95,"function":"OCA\\DAV\\Connector\\Sabre\\{closure}","class":"OCA\\DAV\\Connector\\Sabre\\FilesPlugin","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/FilesPlugin.php","line":346,"function":"handle","class":"Sabre\\DAV\\PropFind","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"handleGetProperties","class":"OCA\\DAV\\Connector\\Sabre\\FilesPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1662,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1647,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":146,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/DB/QueryBuilder/ExpressionBuilder/ExpressionBuilder.php","Line":87,"message":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon.","exception":{},"CustomMessage":"Calling OCP\\DB\\QueryBuilder\\IQueryBuilder::orX without parameters is deprecated and will throw soon."}}
The output of occ config:list system :
            "***REMOVED SENSITIVE VALUE***",
        "dbtype": "mysql",
        "version": "30.0.5.1",
        "overwrite.cli.url": "https:\/\/cloud.bramblecfd.com",
        "dbport": "",
        "mysql.utf8mb4": true,
        "default_phone_region": "GB",
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpsecure": "ssl",
        "mail_smtpauthtype": "LOGIN",
        "mail_smtpauth": 1,
        "mail_smtpport": "465",
        "theme": "",
        "loglevel": 0,
        "filelocking.enabled": true,
        "memcache.locking": "\\OC\\Memcache\\APCu",
        "app_install_overwrite": [
            "impersonate"
        "maintenance_window_start": 1
  - activity: 3.0.0
  - app_api: 4.0.5
  - bruteforcesettings: 3.0.0
  - calendar: 5.0.9
  - circles: 30.0.0
  - comments: 1.20.1
  - contacts: 6.1.3
  - dashboard: 7.10.0
  - dav: 1.31.1
  - deck: 1.14.3
  - federation: 1.20.0
  - files: 2.2.0
  - files_downloadlimit: 3.0.0
  - files_pdfviewer: 3.0.0
  - files_reminders: 1.3.0
  - files_sharing: 1.22.0
  - files_trashbin: 1.20.1
  - files_versions: 1.23.0
  - firstrunwizard: 3.0.0
  - groupfolders: 18.0.10
  - guests: 4.1.0
  - impersonate: 1.17.1
  - logreader: 3.0.0
  - notifications: 3.0.0
  - oauth2: 1.18.1
  - password_policy: 2.0.0
  - photos: 3.0.2
  - polls: 7.2.9
  - privacy: 2.0.0
  - provisioning_api: 1.20.0
  - recommendations: 3.0.0
  - related_resources: 1.5.0
  - serverinfo: 2.0.0
  - settings: 1.13.0
  - sharebymail: 1.20.0
  - spreed: 20.1.3
  - support: 2.0.0
  - survey_client: 2.0.0
  - systemtags: 1.20.0
  - text: 4.1.0
  - theming: 2.5.0
  - updatenotification: 1.20.0
  - user_status: 1.10.0
  - viewer: 3.0.0
  - weather_status: 1.10.0
  - workflowengine: 2.12.0
  - admin_audit: 1.20.0
  - collectives: 2.3.0 (installed 2.3.0)
  - contactsinteraction: 1.11.0 (installed 1.5.0)
  - encryption: 2.18.0
  - files_external: 1.22.0
  - files_rightclick: 0.15.1 (installed 1.6.0)
  - onlyoffice: 7.8.0 (installed 7.8.0)
  - richdocuments: 3.7.6 (installed 3.7.6)
  - suspicious_login: 8.0.0
  - twofactor_totp: 12.0.0-dev
  - user_ldap: 1.21.0
  - whiteboard: 1.0.4 (installed 1.0.4)
So turn off debug level logging. :wink:
The default is 2.
If you visit Admin settings->Overview at the moment there is likely a warning about it for this very reason. :wink:
Hi @jtr
Thank you for the pointer on the debug log level,
that has stopped the spam of those log entries,
In Overview i only have these three things,
so maybe those log entries are just because of php8.1?
    You are currently running PHP 8.1.2-1ubuntu2.20. PHP 8.1 is now deprecated in Nextcloud 30. Nextcloud 31 may require at least PHP 8.2. Please upgrade to one of the officially supported PHP versions provided by the PHP Group as soon as possible. For more details see the
    Could not check for otf loading support. Please check manually if your webserver serves `.otf` files. To allow this check to run you have to make sure that your Web server can connect to itself. Therefore it must be able to resolve and connect to at least one of its `trusted_domains` or the `overwrite.cli.url`. This failure may be the result of a server-side DNS mismatch or outbound firewall rule. For more details see the
    Could not check for WASM loading support. Please check manually if your web server serves `.wasm` files. To allow this check to run you have to make sure that your Web server can connect to itself. Therefore it must be able to resolve and connect to at least one of its `trusted_domains` or the `overwrite.cli.url`. This failure may be the result of a server-side DNS mismatch or outbound firewall rule. For more details see the
Thanks,
In this particular case, those deprecation messages aren’t due to PHP versions, but due to internal API changes in Nextcloud Server. They’re not normally visible other than at the debug loglevel. They are just for devs to remind them of pending API changes.
In the Overview setup checks because there is a check for things like having debug mode on. I mentioned the Overview / setup checks because I was thinking there is also a check for loglevel being set to 0, but I’ve now checked and I was mistaken. There is not currently.
Hi @jtr
Ah okay understood,
thankyou for your help and explanation,
Thanks,
