Hub 10 - Popup “Activate sever-side encryption”
    • 31.0.0
    • Linux 5.10.0-32-amd64 x86_64
    • 8.3.16
    • Yes
    • Update to 31
    • occ app:update --all -n
Does anyone else have the permanently occurring and annoying pop-ups with the following text “Please activate server-side encryption in the administration settings in order to be able to use the encryption module”.
I can click them away but they keep coming back.
  1. Click on anything
  2. Popup comes
        "tempdirectory": "\/tmp",
            "cloud.troeschs.de"
        "dbtype": "mysql",
        "version": "31.0.0.18",
        "overwrite.cli.url": "https:\/\/cloud.***REMOVED SENSITIVE VALUE***.de",
        "overwriteprotocol": "https",
        "dbport": "",
        "mysql.utf8mb4": true,
        "ldapIgnoreNamingRules": false,
        "theme": "",
        "loglevel": 2,
        "twofactor_enforced": "false",
        "twofactor_enforced_groups": [],
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpauth": true,
        "mail_smtpauthtype": "LOGIN",
        "app_install_overwrite": {
            "0": "occweb",
            "1": "calendar",
            "2": "flowupload",
            "3": "documentserver_community",
            "4": "news",
            "6": "gpoddersync",
            "7": "files_rightclick",
            "8": "forms"
        "encryption.legacy_format_support": false,
        "encryption.key_storage_migrated": false,
        "default_phone_region": "DE",
        "forbidden_filename_basenames": [
            "con",
            "prn",
            "aux",
            "nul",
            "com0",
            "com1",
            "com2",
            "com3",
            "com4",
            "com5",
            "com6",
            "com7",
            "com8",
            "com9",
            "com\u00b9",
            "com\u00b2",
            "com\u00b3",
            "lpt0",
            "lpt1",
            "lpt2",
            "lpt3",
            "lpt4",
            "lpt5",
            "lpt6",
            "lpt7",
            "lpt8",
            "lpt9",
            "lpt\u00b9",
            "lpt\u00b2",
            "lpt\u00b3"
        "forbidden_filename_characters": [
        "forbidden_filename_extensions": [
            ".filepart",
            ".part"
  - activity: 4.0.0
  - app_api: 5.0.2
  - bruteforcesettings: 4.0.0
  - calendar: 5.1.2
  - circles: 31.0.0-dev.0
  - comments: 1.21.0
  - contacts: 7.0.1
  - contactsinteraction: 1.12.0
  - dashboard: 7.11.0
  - dav: 1.33.0
  - encryption: 2.19.0
  - federation: 1.21.0
  - files: 2.3.1
  - files_downloadlimit: 4.0.0
  - files_pdfviewer: 4.0.0
  - files_reminders: 1.4.0
  - files_sharing: 1.23.1
  - files_trashbin: 1.21.0
  - files_versions: 1.24.0
  - firstrunwizard: 4.0.0
  - forms: 5.0.0
  - gpoddersync: 3.12.0
  - logreader: 4.0.0
  - mail: 4.2.2
  - news: 25.2.1
  - notifications: 4.0.0
  - oauth2: 1.19.1
  - password_policy: 3.0.0
  - photos: 4.0.0-dev.1
  - polls: 7.3.2
  - privacy: 3.0.0
  - profile: 1.0.0
  - provisioning_api: 1.21.0
  - recommendations: 4.0.0
  - related_resources: 2.0.0
  - richdocuments: 8.6.1
  - richdocumentscode: 24.4.1204
  - serverinfo: 3.0.0
  - settings: 1.14.0
  - sharebymail: 1.21.0
  - support: 3.0.0
  - survey_client: 3.0.0
  - suspicious_login: 9.0.1
  - systemtags: 1.21.1
  - text: 5.0.0
  - theming: 2.6.1
  - updatenotification: 1.21.0
  - user_status: 1.11.0
  - viewer: 4.0.0
  - weather_status: 1.11.0
  - webhook_listeners: 1.2.0
  - workflowengine: 2.13.0
  - admin_audit: 1.21.0
  - files_external: 1.23.0
  - user_ldap: 1.22.0 (installed 1.6.0)
No, but that’s probably because I’ve disabled the encryption module.
To disable it, go to Settings → Apps → Active apps, find the Default encryption module and click Disable.
Alternatively, you can also disable it from the command line:
occ app:disable encryption
Hope that helps.
Thank you very much.
Funnily enough, I hadn’t even activated the app.
It must have been activated automatically during the update.
