I have no support/technical question and have seen the support category. (Be aware that direct support questions will be deleted.)
on
Which general topic do you have
I updated my test platform Nextcloud instance to Hub 10.
The dashboard UI interface has been stylized vertically rather than horizontally. The menus now require multiple clicks on a desktop browser. This is not desirable behavior for a desktop user. However, it’s not terrible.
However, the dashboard drop down menu interferes with app menus. This is particularly problematic when using the Calendar. The “previous month” button on the calendar is overlaid by the dashboard drop down menu. So, when attempting to go backward in the Calendar, the dashboard drop down is activated instead of the Calendar “previous month” function.
I’ve searched through the options, and can not locate a “mobile/desktop” option or some other obvious way to change the drop down dashboard back to a horizontal one-click menu. If such option is not available, Calendar use is going to be difficult for desktop users.
