First a bit technical details:
Ubuntu 18.04
Nextcloud - apache2
Im not entirely sure how to do this.
I have my router set to forward a port 3456 to that internal IP adress
I consider using a selfsigned cert as the letsencrypt wont fetch for some reason ( its giving me error of possible firewall issue )
Anyway the documentation tells me to use redirect permanent in a file.
I take it that its the nextcloud.conf file in my /etc/apache2/sites-available that its talking about ?
Its a bit tricky when it doesn mention exactly which files to edit.
Do i need to specify the port in the redirect part ? And should i open an extra port on the router ??
Is it simply the local server listening to another port ( https instead of http ) so i wont need to redirect even another port in the router ?
A side question is: Which ports should i have opened in its local firewall once im done ?? 80 433 and what else ? Im using teamviewer to remote access it for the time being ( as i work on it while at work )
