I’m new user of nextcloud and i’m facing issue.
I’m using a Shared hosting server ovh.
Nextcloud version : 15
Operating system and version : I don’t know
Apache or nginx version : I don’t know
PHP version : 7.2
My cloud work correctly in http but when i try to switch https it doesn’t work.
I can’t log in https and when i log in htttp and switch to https the home page is empty…
HTTPS is actived and it work my certificate is let’s encrypte
Log is empty
'instanceid' => 'oczmmajqude8',
'passwordsalt' => 'XXXXXXXXXXXXX',
'secret' => 'XXXXXXXXXXXX',
0 => 'www.nextcloud-perso.tremblin.fr',
'datadirectory' => '/home/tremblinlu/MyNextCloud/nextcloud/data',
'version' => '15.0.2.0',
'overwrite.cli.url' => 'http://www.nextcloud-perso.tremblin.fr/nextcloud',
'dbname' => 'tremblinluovhdb',
'dbhost' => 'tremblinluovhdb.mysql.db',
'dbuser' => 'xxxxxxxx',
'dbpassword' => 'xxxxxxx',
Please help.thanks
