I have installed nextcloud16 using viewtopic.php?f=189&t=10351. I am able to create a postgresql database and able to login to nextcloud protal via http locally and over the internet.
I have tried to change the settings in the config file for nextcloud also for https and if i do so i get an error that please check the config.sample file for proper configuration.
using http i am able to reach the page by http://192.168.1.198/801/nextcloud16 it redirects from asustor login page http://192.168.1.198:8002.
Over the internet i am able to access asustor page via https://asusterID.myasustor.com:8002…but when i try to access nextcloud it redirects to http://asustorID.myasustor.com:801/nextcloud16
I have try to change the virtualhost settings, but i was not sure exactly, so revert it back…
This is what i have tested till now for the config file
0 => ‘192.168.1.198:801’,
1 => ‘asustorID.myasustor.com:443/nextcloud16’
‘datadirectory’ => ‘/volume1/Web/nextcloud16/data’,
‘dbtype’ => ‘pgsql’,
‘version’ => ‘16.0.1.1’,
‘overwrite.cli.url’ => ‘https://asustorID.myasustor.com:443/nextcloud16’,
‘overwriteprotocol’ => ‘https’,
I know i am doing something wrong, but not sure what. I have already opened port 443 in my router. If somebody can help me with this that would be great
