Good Day everyone.
Just thought I would reach out since I have been dealing with this for a bit, but I am getting the feeling from my research on the issue I wont get much help. But here goes nothing?
So I have been hosting a next cloud server since … I dont know … 2013? ish? But it was only recently that I got real serious around 2016 and setup an ESXi Host with the VM installed and connected it to a 2012 r2 AD with an Exchange Mail server and File Server running 2008 r2 (has since been migrated to 2012 r2)
So since I was learning a lot on this server (just a private lab for family and friends) I did a lot of experimenting. So, recently my server, at random intervals would delete everything in my account from one of the synced (sp?) computers. It was like they had some sort of ‘old info’ that would suddenly become ‘current’ and the account would sync to it. Never could figure out who, or why. But I would just wake up one morning and have no files lol.
So rather than try to figure this out (started on 10 with ubuntu LTS16.04) I just decided to start fresh
Well here I am. So I just finished using couple of tutorials to get this done:
https://docs.nextcloud.com/server/18/admin_manual/configuration_user/user_auth_ldap.html
had to adjust a few things (looking at you Rigis!!!) but got it working. Well I started installing it on my various computers that i use for work and home (total of 5 running 10 or 7 pro x64) and I am now getting that error that many have reported. But it only started when I started syncing the client. Now I can see that some are noting that it may be a bug or because of sharing external storage files that they did not have access to or other ‘credential based errors’ … I checked AD logs and found these little gems:
The computer attempted to validate the credentials for an account.
Authentication Package: MICROSOFT_AUTHENTICATION_PACKAGE_V1_0
Logon Account: A363A5EC-FBDB-****-BF7D-5812851BC2AF
Source Workstation: CLOUD
Error Code: 0xC0000064
Okay that is weird … … and then looking at ‘users’ I see this:
What is with all the SIDs?
I replicated the AD Sync and the settings say ‘okay’ but I am getting those “Icewind\SMB\Exception\ForbiddenException” errors in the event viewer, and this one:
[user_ldap] Warning: Configuration Error (prefix s01): either no password is given for the user agent or a password is given, but not an LDAP agent.
HEAD /remote.php/webdav/Family%20Media%20(F)/Pictures/AutoUploads/CharlesandAileenHix/2020/01/
from 50.206.170.140 at 2020-01-30T01:27:32+00:100
So there is ‘something’ wrong with AD sync.
So I joined the server to the domain (the other one was) no change.
my only thought was that maybe there was something to do with the expiring SSL on the server for SLDAP, but it is not until later this month… Should i create a new one?
Then again… I am not using SLDAP to connect:
So there it is… what do you guys think i did wrong?
Here is the requested information from the template:
Nextcloud version : 18.0.0
Operating system and version : Ubuntu 18.04 LTS
Apache or nginx version : Apache 2.4.25
PHP version : 7.2.24, Memory limit (2GB)
Is this the first time you’ve seen this error? : Yes
- Install Windows Desktop Sync 2.6.2
- log in
- Profit
[no app in context] Error: Icewind\SMB\Exception\ForbiddenException: Invalid request for / (ForbiddenException) at <<closure>>
0. /var/www/html/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeState.php line 62
Icewind\SMB\Exception\Exception::fromMap({1: "Icewind\\SM ... "}, 1, "/")
1. /var/www/html/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeState.php line 74
Icewind\SMB\Native\NativeState->handleError("/")
2. /var/www/html/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeState.php line 184
Icewind\SMB\Native\NativeState->testResult(false, "smb://hix-server2016/Users/")
3. /var/www/html/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeShare.php line 133
Icewind\SMB\Native\NativeState->stat("smb://hix-server2016/Users/")
4. /var/www/html/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeShare.php line 112
Icewind\SMB\Native\NativeShare->getStat("/")
5. /var/www/html/nextcloud/apps/files_external/lib/Lib/Storage/SMB.php line 179
Icewind\SMB\Native\NativeShare->stat("/")
6. /var/www/html/nextcloud/apps/files_external/lib/Lib/Storage/SMB.php line 297
OCA\Files_External\Lib\Storage\SMB->getFileInfo("/")
7. /var/www/html/nextcloud/lib/private/Files/Storage/Common.php line 456
OCA\Files_External\Lib\Storage\SMB->stat("")
8. /var/www/html/nextcloud/apps/files_external/lib/Lib/Storage/SMB.php line 613
OC\Files\Storage\Common->test()
9. /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php line 472
OCA\Files_External\Lib\Storage\SMB->test()
10. /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php line 472
OC\Files\Storage\Wrapper\Wrapper->test()
11. /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php line 472
12. /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Availability.php line 69
13. /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Availability.php line 83
OC\Files\Storage\Wrapper\Availability->updateAvailability("*** sensitive parameters replaced ***")
14. /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Availability.php line 92
OC\Files\Storage\Wrapper\Availability->isAvailable()
15. /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Availability.php line 441
OC\Files\Storage\Wrapper\Availability->checkAvailability()
16. /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php line 582
OC\Files\Storage\Wrapper\Availability->getMetaData("")
17. /var/www/html/nextcloud/lib/private/Files/Cache/Scanner.php line 113
OC\Files\Storage\Wrapper\Wrapper->getMetaData("")
18. /var/www/html/nextcloud/lib/private/Files/Cache/Scanner.php line 151
OC\Files\Cache\Scanner->getData("")
19. /var/www/html/nextcloud/lib/private/Files/View.php line 1484
OC\Files\Cache\Scanner->scanFile("")
20. /var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php line 265
OC\Files\View->getDirectoryContent("/")
21. /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php line 195
OCA\DAV\Connector\Sabre\Directory->getChildren()
22. /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 899
Sabre\DAV\Tree->getChildren("files/A363A5EC- ... F")
23. /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 978
Sabre\DAV\Server->generatePathNodes(Sabre\DAV\PropFind {}, [Sabre\DAV\PropF ... }])
24. /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1666
Sabre\DAV\Server->getPropertiesIteratorForPath("files/A363A5EC- ... F", ["{DAV:}resource ... "], 1)
25. /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 355
Sabre\DAV\Server->generateMultiStatus(Generator {}, false)
26. <<closure>>
Sabre\DAV\CorePlugin->httpPropFind(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
27. /var/www/html/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php line 105
call_user_func_array([Sabre\DAV\CorePlugin {},"httpPropFind"], [Sabre\HTTP\Requ ... }])
28. /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 479
Sabre\Event\EventEmitter->emit("method:PROPFIND", [Sabre\HTTP\Requ ... }])
29. /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 254
Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
30. /var/www/html/nextcloud/apps/dav/lib/Server.php line 319
Sabre\DAV\Server->exec()
31. /var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php line 35
OCA\DAV\Server->exec()
32. /var/www/html/nextcloud/remote.php line 165
require_once("/var/www/html/n ... p")
PROPFIND /remote.php/dav/files/A363A5EC-FBDB-40D5-BF7D-5812851BC2AF/
from 74.202.141.227 by A363A5EC-FBDB-40D5-BF7D-5812851BC2AF at 2020-01-30T01:03:35+00:00
Output of config.php
'instanceid' => '[redacted]',
'passwordsalt' => '[redacted]',
'secret' => '[redacted]',
0 => 'cloud.hixfamily.us',
1 => '[redacted]',
2 => '[redacted]',
3 => '[redacted]',
'datadirectory' => '/var/nextcloud/data',
'version' => '18.0.0.10',
'overwrite.cli.url' => 'https://cloud.hixfamily.us',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => '[redacted]',
'dbpassword' => '[redacted]',
'redis' =>
'port' => 0,
'timeout' => 0.0,
'ldapIgnoreNamingRules' => false,
The output of your Apache/nginx/system log in /var/log/apache2/error.log
[Wed Jan 29 06:25:02.749172 2020] [mpm_prefork:notice] [pid 8725] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.1 configured -- resuming normal operations
[Wed Jan 29 06:25:02.749233 2020] [core:notice] [pid 8725] AH00094: Command line: '/usr/sbin/apache2'
[Wed Jan 29 10:49:57.341643 2020] [php7:error] [pid 2670] [client 145.239.69.74:36786] script '/var/www/html/wp-login.php' not found or unable to stat
[Wed Jan 29 11:25:47.081247 2020] [php7:error] [pid 2668] [client 13.73.159.163:55999] script '/var/www/html/xmlrpc.php' not found or unable to stat
[Wed Jan 29 11:30:23.904244 2020] [php7:error] [pid 2666] [client 46.101.150.9:50486] script '/var/www/html/wp-login.php' not found or unable to stat
[Wed Jan 29 18:14:39.957387 2020] [php7:error] [pid 2668] [client 193.57.40.38:41600] script '/var/www/html/index.php' not found or unable to stat
[Thu Jan 30 01:03:30.941027 2020] [access_compat:error] [pid 16021] [client 74.202.141.227:11571] AH01797: client denied by server configuration: /var/www/html/nextcloud/config
cat: /etc/ntp.conf: No such file or directory
Output of the log that Apache2 is referncing “/var/www/html/nextcloud/config”
" Netrw Directory Listing (netrw v156)
" /var/www/html/nextcloud/config
" Sorted by name
" Sort sequence: [\/]$,\<core\%(\.\d\+\)\=\>,\.h$,\.c$,\.cpp$,\~\=\*$,*,\.o$,\.obj$,\.info$,\.swp$,\.bak$,\~$
" Quick Help: <F1>:help -:go up dir D:delete R:rename s:sort-by x:special
.htaccess
config.php
config.sample.php
config.php.bak
