Nextcloud version (eg, 15.0.7.0): 15.0.7.0
Operating system and version (eg, Ubuntu 17.04): Raspbian 9.8
Apache or nginx version (eg, Apache 2.4.25): 2.4.25
PHP version (eg, 7.1): 7.0.33-0+deb9u3
After cleaning up the preview folder of nextcloud and some of the logs on the raspberry because I ran out of space, I am always getting the the Error “HTTP ERROR 500” when I am trying to connect to my Nextcloud.
Restarting MariaDB manually failed.
What is still working:
- view the Apache2 default page
- view the phpInfo() page
I would be very happe if someone could help me
already rebooted several times, problem remains
config.php
'instanceid' => 'myID',
'passwordsalt' => 'myPassword',
'secret' => 'mySecret',
0 => '192.xxx.xxx.30',
1 => 'xxx.local',
2 => '192.xxx.xxx.34',
'datadirectory' => '/var/www/html/nextcloud/data',
'overwrite.cli.url' => 'https://192.xxx.xxx.30/nextcloud',
'version' => '15.0.7.0',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'username',
'dbpassword' => 'mypasswort',
'skeletondirectory' => '',
'theme' => '',
'loglevel' => 0,
'mail_smtpmode' => 'smtp',
Some of my system log:
Aug 14 15:05:35 cloud systemd[1]: Failed to start MariaDB 10.1.37 database server.
Aug 14 15:05:35 cloud systemd[1]: mariadb.service: Unit entered failed state.
Aug 14 15:05:35 cloud systemd[1]: mariadb.service: Failed with result 'exit-code'.
More information on MariaDB:
MariaDB status
● mariadb.service - MariaDB 10.1.37 database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2019-08-14 16:05:32 UTC; 46min ago
Docs: man:mysqld(8)
https://mariadb.com/kb/en/library/systemd/
Process: 717 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, status=1/FAILURE)
Process: 634 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=`/usr/bin/galera_recovery`; [ $? -eq 0 ] && systemctl set-environment _WSREP
Process: 620 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 573 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
Main PID: 717 (code=exited, status=1/FAILURE)
Status: "MariaDB server is down"
Aug 14 16:05:19 cloud systemd[1]: Starting MariaDB 10.1.37 database server...
Aug 14 16:05:22 cloud mysqld[717]: 2019-08-14 16:05:22 1996185392 [Note] /usr/sbin/mysqld (mysqld 10.1.37-MariaDB-0+deb9u1) starting as process 717 ...
Aug 14 16:05:32 cloud systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Aug 14 16:05:32 cloud systemd[1]: Failed to start MariaDB 10.1.37 database server.
Aug 14 16:05:32 cloud systemd[1]: mariadb.service: Unit entered failed state.
Aug 14 16:05:32 cloud systemd[1]: mariadb.service: Failed with result 'exit-code'.
The output of your Apache log in /var/log/____
Apache log
Wed Aug 14 15:48:05.925307 2019] [ssl:warn] [pid 613] AH01909: 127.0.1.1:443:0 server certificate does NOT include an ID which matches the server name
[Wed Aug 14 15:48:09.552904 2019] [ssl:warn] [pid 775] AH01909: 127.0.1.1:443:0 server certificate does NOT include an ID which matches the server name
[Wed Aug 14 15:48:09.568125 2019] [mpm_prefork:notice] [pid 775] AH00163: Apache/2.4.25 (Raspbian) OpenSSL/1.0.2r configured -- resuming normal operations
[Wed Aug 14 15:48:09.579690 2019] [core:notice] [pid 775] AH00094: Command line: '/usr/sbin/apache2'
[Wed Aug 14 15:52:13.521984 2019] [:error] [pid 816] [client 192.168.178.32:55979] PHP Fatal error: Uncaught Error: Class 'RedisCluster' not found in /var/www/html/nextcloud/config/config.php:1176\nStack trace:\n#0 /var/www/html/nextcloud/lib/private/Config.php(214): include()\n#1 /var/www/html/nextcloud/lib/private/Config.php(63): OC\\Config->readData()\n#2 /var/www/html/nextcloud/lib/base.php(140): OC\\Config->__construct('/var/www/html/n...')\n#3 /var/www/html/nextcloud/lib/base.php(591): OC::initPaths()\n#4 /var/www/html/nextcloud/lib/base.php(1068): OC::init()\n#5 /var/www/html/nextcloud/index.php(40): require_once('/var/www/html/n...')\n#6 {main}\n thrown in /var/www/html/nextcloud/config/config.php on line 1176
[Wed Aug 14 16:05:11.014602 2019] [mpm_prefork:notice] [pid 775] AH00169: caught SIGTERM, shutting down
[Wed Aug 14 16:05:21.968966 2019] [ssl:warn] [pid 610] AH01909: 127.0.1.1:443:0 server certificate does NOT include an ID which matches the server name
[Wed Aug 14 16:05:25.854435 2019] [ssl:warn] [pid 779] AH01909: 127.0.1.1:443:0 server certificate does NOT include an ID which matches the server name
[Wed Aug 14 16:05:25.869859 2019] [mpm_prefork:notice] [pid 779] AH00163: Apache/2.4.25 (Raspbian) OpenSSL/1.0.2r configured -- resuming normal operations
[Wed Aug 14 16:05:25.870011 2019] [core:notice] [pid 779] AH00094: Command line: '/usr/sbin/apache2'
[Wed Aug 14 16:14:52.554264 2019] [:error] [pid 816] [client 192.xxx.xxx.xx:45984] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
[Wed Aug 14 16:14:52.555524 2019] [:error] [pid 819] [client 192.xxx.xxx.xx:45980] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
[Wed Aug 14 16:16:40.902178 2019] [:error] [pid 816] [client 192.xxx.xxx.xx:46138] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
[Wed Aug 14 16:16:41.079340 2019] [:error] [pid 1167] [client 192.xxx.xxx.xx:46140] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
[Wed Aug 14 16:16:41.082422 2019] [:error] [pid 1167] [client 192.xxx.xxx.xx:46140] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
[Wed Aug 14 16:16:41.249392 2019] [:error] [pid 819] [client 192.xxx.xxx.xx:46142] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
[Wed Aug 14 16:16:41.252492 2019] [:error] [pid 819] [client 192.xxx.xxx.xx:46142] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
[Wed Aug 14 16:16:41.427488 2019] [:error] [pid 817] [client 192.xxx.xxx.xx:46144] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
[Wed Aug 14 16:16:41.430603 2019] [:error] [pid 817] [client 192.xxx.xxx.xx:46144] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
[Wed Aug 14 16:16:41.610492 2019] [:error] [pid 1168] [client 192.xxx.xxx.xx:46146] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
[Wed Aug 14 16:16:41.613528 2019] [:error] [pid 1168] [client 192.xxx.xxx.xx:46146] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
[Wed Aug 14 16:16:42.531263 2019] [:error] [pid 1169] [client 192.xxx.xxx.xx:46148] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
[Wed Aug 14 16:16:42.536399 2019] [:error] [pid 1169] [client 192.xxx.xxx.xx:46148] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
[Wed Aug 14 16:16:42.972633 2019] [:error] [pid 820] [client 192.xxx.xxx.xx:46150] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
[Wed Aug 14 16:16:42.975324 2019] [:error] [pid 820] [client 192.xxx.xxx.xx:46150] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrin in /var/www/html/nextcloud/lib/private/DB/Connection.php on line 64
