This site is accessed via an insecure HTTP protocol. Instead, we strongly recommend that you configure the server to require HTTPS, as described in our security tips.
Yes, that is a good advice. To enable https, configure your web server.
I set everything according to the instructions and still can not and I do not know where to set it
Which instructions did you follow? What is the content of your apache virtual host file?
