Nextcloud version (eg, 12.0.2): 13.0.1
Operating system and version (eg, Ubuntu 17.04): Arch Linux 64-bit
Apache or nginx version (eg, Apache 2.4.25): 2.4.33
PHP version (eg, 7.1): 7.2.5
I’m not really facing an issue, just wondering how to do the above. I have nextcloud server running on my machine, and 4 other machines using it using the nextcloud client. However I’d like my host machine (let’s call it machine A) to also be able to use the files shared from nextcloud without duplicating them.
In other words, I have nextcloud’s data in (for example) A:/var/www/nextcloud/data
And on my other machines, it’s all synced to ~/Nextcloud
How can I get A to also have ~/Nextcloud in such a way that changes I make while running A both get propagated (data) correctly. I’ve tried just symlinking or bind-mounting the folders, but deletions, for example, don’t show up in the web interface (although trying to access the deleted file obviously fails).
