example
longer
example
here
Nextcloud version (eg, 20.0.5): Nextcloud All-In-One (AIO)
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): Using Nextcloud AIO (Apache)
PHP version (eg, 7.4): Using Nextcloud AIO
I have been running Nextcloud AIO without any issues for many months. Today, I went to update the master container but the backup can’t complete because storage is full. I am going to use another backup solution so I want to disable the built-in backup with borg.
I stopped the master container with the command:
sudo docker stop [container-id]
Now I want to start the master container again with backup disabled. The docs say you can do so by adding -e DISABLE_BACKUP_SECTION=true
to the initial startup of the mastercontainer.
I tried running the following command to start the container with backup disabled:
sudo docker start [container-id] -e DISABLE_BACKUP_SECTION=true
However it shows the message unknown shorthand flag: 'e' in -e
What is the command to restart the master container with backup disabled?
- Stop master container with
. - Try to start master container with
