How to show upload speed in Nextcloud 26 / 27?
example
longer
example
here
Nextcloud version (eg, 20.0.5): Nextcloud 26.0.4 / Nextcloud 27.0.1
Operating system and version (eg, Ubuntu 20.04): TrueNAS 12.0U8.1 (Jail FreeBSD 12.4-RELEASE)
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.53 (FreeBSD)
PHP version (eg, 7.4): 8.2.8
In Nextcloud 24, I can show the upload speed if I hover the progress bar. However, I cannot show the upload speed in Nextcloud 27. I tried Nextcloud 26 and get the same result.
  1. Upload file
  2. Hover the progress bar
[index] Error: RuntimeException: Could not get appdata folder for theming at <<closure>>
0. /usr/local/www/nextcloud/lib/private/Files/AppData/AppData.php line 147
   OC\Files\AppData\AppData->getAppDataFolder()
1. /usr/local/www/nextcloud/apps/theming/lib/ImageManager.php line 383
   OC\Files\AppData\AppData->newFolder()
2. /usr/local/www/nextcloud/apps/theming/lib/ImageManager.php line 118
   OCA\Theming\ImageManager->getRootFolder()
3. /usr/local/www/nextcloud/apps/theming/lib/Controller/IconController.php line 118
   OCA\Theming\ImageManager->getImage()
4. /usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 230
   OCA\Theming\Controller\IconController->getFavicon()
5. /usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 137
6. /usr/local/www/nextcloud/lib/private/AppFramework/App.php line 183
7. /usr/local/www/nextcloud/lib/private/Route/Router.php line 315
   OC\AppFramework\App::main()
8. /usr/local/www/nextcloud/lib/base.php line 1071
   OC\Route\Router->match()
9. /usr/local/www/nextcloud/index.php line 36
   OC::handleRequest()
GET /index.php/apps/theming/favicon?v=05d8a664
from local IP by ncadmin at 2023-07-27T04:11:48+00:00
  'instanceid' => 'oc09hnbyhcoq',
  'passwordsalt' => '',
  'secret' => '',
    0 => 'nextcloud.mydomain.tld',
  'datadirectory' => '/usr/local/www/nextcloud/data',
  'version' => '27.0.1.2',
  'overwrite.cli.url' => 'https://nextcloud.mydomain.tld',
  'dbname' => 'nextcloud',
  'dbhost' => 'localhost:/tmp/mysql.sock',
  'dbuser' => 'xxx',
  'dbpassword' => 'xxx',
  'redis' =>
    'host' => '/var/run/redis/redis.sock',
    'port' => 0,
[Thu Jul 27 04:12:35.418638 2023] [mpm_event:notice] [pid 62394:tid 34370936832] AH00491: caught SIGTERM, shutting down
[Thu Jul 27 04:12:35.548780 2023] [mpm_event:notice] [pid 62573:tid 34370936832] AH00489: Apache/2.4.53 (FreeBSD) OpenSSL/1.1.1h-freebsd configured -- resumingnormal operations
[Thu Jul 27 04:12:35.549199 2023] [core:notice] [pid 62573:tid 34370936832] AH00094: Command line: '/usr/local/sbin/httpd -D NOHTTPACCEPT'
[Thu Jul 27 04:12:11.836750 2023] [access_compat:error] [pid 62397:tid 34385381888] [client localIP:35472] AH01797: client denied by server configuration: /usr/local/www/nextcloud/data/.ocdata
[Thu Jul 27 04:12:44.088556 2023] [access_compat:error] [pid 62577:tid 34385385728] [client localIP:35872] AH01797: client denied by server configuration: /usr/local/www/nextcloud/data/.ocdata
It works for me, but only when I put the mouse pointer to the very bottom of the progress bar. I would estimate that the area where it works has a height of about three to four pixels max.
Thank you, it does show an instantaneous upload speed in the bottom.
In Nextcloud 24, the speed keeps updating. It is still hard to monitor the performance in Nextcloud 27.
