I’m encoutering issue with a small instance (15 accounts).
There’s a group folder with all files for theses accounts and I don’t know how to avoid user duplicating folders and files while using the sync client.
For example, they had the folder “1 - Invoice”
And now they have “1 - Invoice (1)” due to someone messing up with the sync client…
This happen a lot and I don’t really know how I can avoid this, they need the sync client in both way (from and to the server) so just disabling this is not an option.
Regards
