Hello.
Im using Nextcloud 11 VM deployment and i need in Webmin mount share from another server
but, if i try mount nfs, nextcloud can not see NFS hostname - No local NFS servers found
NAS and nextcloud are in the same network and ping each other is working…
with SMB is the same problém…
i need mount NFS NAS datastore for storaging users data to NAS datastore
Is this the official VM or your own?
Yes, its official virtual from nextcloud’s page.
Just use the External Storage App, or mount NFS/SMB in Linux. All the prerequisites are there for the External Storage’s App, ready to be used. So it’s not a VM issue, rather a configuration issue.
Though depending on how you do it you may have to install CIFS and NFS client/server packages in Linux. Here’s a guide I made a while ago: https://www.techandme.se/create-cifs-smb-share-from-windows-ubuntu/
Also, you should update to 12 by typing: sudo bash /var/scripts/update.sh
