Hi there!
What is the easiest way to migrate a manual installation to Nextcloud Pi? Is there any tool to do this? I am using sqlite with the manual installation. Would I need to migrate to mysql first?
Thanks a lot for your help!
Hi there!
I’m not aware of a tool to automatically do this - but it shouldn’t be too complicated to do this manually:
config.php
to new instanceconfig.php
accordinglyconfig.php
This is of course just a very coarse guide, make sure to always back up things properly and try to keep your current instance untouched to in case things go wrong you can simply restart that one again.
Thanks for your advice! I will copy the config and data directory. I will try getting it running with sqlite and move to mysql later.
