example
longer
example
here
Nextcloud version (eg, 20.0.5): 23.0.2
Operating system and version (eg, Ubuntu 20.04): Debian/Raspbian 11 Bullseye
Apache or nginx version (eg, Apache 2.4.25): * Apache 2.4.25, with HTTP2 enabled
PHP version (eg, 7.4): 7.4
Hi all,
I have an issue with the drive management of the NextcloudPi.
Here my desired setup:
RaspberryPi4 with a SSD running the OS. (But this is done via USB)
2 Drives, one for the Data and one for Backup.
No I have really big problems in setting it up, every time I am done with configuration (Which is by the way very easy and conveniant! ) I can not set up any further USB drives because I can not unplug the SSD and if if format a new USB drive everything ( including my OS SSD) is erased.
Do you have any suggestions how to set it up?
I want to use it as my main file system for all data. so I want it to be robust with auto Backups. And the SSD is there for speed.
I mean I could set it up using an SD card and then clone the SD card to the SSD once I’m done. but then I still can not make any changes to the USB drives.
Do you have any suggestions for me?
Thank you in advance!
Best regards,
Daniel
