I recently setup nextcloud 20.0.0 on my server and PHP version is 7.4 but when i try to upload files i get message “Operation is blocked by access control”
can you guys please help me to fix it ?
Could you please use the template?
@sturtz_nate sorry for not follwing the format
example
longer
examp
here
Nextcloud version : 20.0.0
Operating system and version : Ubuntu 20.04
Apache or nginx version : nginx - runcloud.io
PHP version : 7.4
when i try to upload .zip files, I get the error “Operation is blocked by access control”
Is this the first time you’ve seen this error? (Y/N): I just installed a fresh copy of nextcloud
- try to upload .zip file
{"reqId":"niTSz22alJ8wGKTKkt9Z","level":4,"time":"2020-10-12T14:17:26+00:00","remoteAddr":"122.174.192.109","user":"Rathana Puducherry","app":"webdav","method":"DELETE","url":"/remote.php/dav/files/Rathana%20Puducherry/Documents","message":{"Exception":"Doctrine\\DBAL\\Exception\\DeadlockException","Message":"An exception occurred while executing 'UPDATE `oc_filecache` SET `mtime` = GREATEST(`mtime`, ?), `etag` = ? WHERE (`storage` = ?) AND (`path_hash` IN ('d41d8cd98f00b204e9800998ecf8427e', '45b963397aa40d4a0063e0d85e4fe7a1'))' with params [1602512246, \"5f846576144a9\", 5]:\n\nSQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","Code":0,"Trace":[{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php","line":169,"function":"convertException","class":"Doctrine\\DBAL\\Driver\\AbstractMySQLDriver","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php","line":149,"function":"wrapException","class":"Doctrine\\DBAL\\DBALException","type":"::"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php","line":1071,"function":"driverExceptionDuringQuery","class":"Doctrine\\DBAL\\DBALException","type":"::"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/DB/Connection.php","line":214,"function":"executeUpdate","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php","line":209,"function":"executeUpdate","class":"OC\\DB\\Connection","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/DB/QueryBuilder/QueryBuilder.php","line":217,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/Cache/Propagator.php","line":100,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/Cache/HomePropagator.php","line":49,"function":"propagateChange","class":"OC\\Files\\Cache\\Propagator","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/Cache/Updater.php","line":166,"function":"propagateChange","class":"OC\\Files\\Cache\\HomePropagator","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/View.php","line":329,"function":"remove","class":"OC\\Files\\Cache\\Updater","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/View.php","line":1173,"function":"removeUpdate","class":"OC\\Files\\View","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/View.php","line":350,"function":"basicOperation","class":"OC\\Files\\View","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/apps/dav/lib/Connector/Sabre/Directory.php","line":309,"function":"rmdir","class":"OC\\Files\\View","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/Tree.php","line":183,"function":"delete","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":295,"function":"delete","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpDelete","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/Server.php","line":474,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/Server.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/Server.php","line":319,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/apps/dav/lib/Server.php","line":325,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/remote.php","line":167,"args":["/home/shivalingamtransports/webapps/shivalingamtransports/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php","Line":34,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDOException","Message":"SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","Code":"40001","Trace":[{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php","line":1062,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDOStatement","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/DB/Connection.php","line":214,"function":"executeUpdate","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php","line":209,"function":"executeUpdate","class":"OC\\DB\\Connection","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/DB/QueryBuilder/QueryBuilder.php","line":217,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/Cache/Propagator.php","line":100,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/Cache/HomePropagator.php","line":49,"function":"propagateChange","class":"OC\\Files\\Cache\\Propagator","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/Cache/Updater.php","line":166,"function":"propagateChange","class":"OC\\Files\\Cache\\HomePropagator","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/View.php","line":329,"function":"remove","class":"OC\\Files\\Cache\\Updater","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/View.php","line":1173,"function":"removeUpdate","class":"OC\\Files\\View","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/View.php","line":350,"function":"basicOperation","class":"OC\\Files\\View","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/apps/dav/lib/Connector/Sabre/Directory.php","line":309,"function":"rmdir","class":"OC\\Files\\View","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/Tree.php","line":183,"function":"delete","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":295,"function":"delete","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpDelete","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/Server.php","line":474,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/Server.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/Server.php","line":319,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/apps/dav/lib/Server.php","line":325,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/remote.php","line":167,"args":["/home/shivalingamtransports/webapps/shivalingamtransports/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php","Line":129,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","Code":"40001","Trace":[{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php","line":127,"function":"execute","class":"PDOStatement","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php","line":1062,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDOStatement","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/DB/Connection.php","line":214,"function":"executeUpdate","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php","line":209,"function":"executeUpdate","class":"OC\\DB\\Connection","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/DB/QueryBuilder/QueryBuilder.php","line":217,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/Cache/Propagator.php","line":100,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/Cache/HomePropagator.php","line":49,"function":"propagateChange","class":"OC\\Files\\Cache\\Propagator","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/Cache/Updater.php","line":166,"function":"propagateChange","class":"OC\\Files\\Cache\\HomePropagator","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/View.php","line":329,"function":"remove","class":"OC\\Files\\Cache\\Updater","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/View.php","line":1173,"function":"removeUpdate","class":"OC\\Files\\View","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/lib/private/Files/View.php","line":350,"function":"basicOperation","class":"OC\\Files\\View","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/apps/dav/lib/Connector/Sabre/Directory.php","line":309,"function":"rmdir","class":"OC\\Files\\View","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/Tree.php","line":183,"function":"delete","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":295,"function":"delete","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpDelete","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/Server.php","line":474,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/Server.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/sabre/dav/lib/DAV/Server.php","line":319,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/apps/dav/lib/Server.php","line":325,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/home/shivalingamtransports/webapps/shivalingamtransports/remote.php","line":167,"args":["/home/shivalingamtransports/webapps/shivalingamtransports/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/home/shivalingamtransports/webapps/shivalingamtransports/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php","Line":127}},"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/86.0.4240.75 Safari/537.36","version":"20.0.0.9","id":"5f8481ea3431b"}
SOP Revision 3.zip
ok before you upload it try to rename it to sop_revision_3.zip then try to upload it
not working, still same issue “Operation is blocked by access control”
ok do you have flowupload enabled?
The app flow upload
its a fresh install and i did not change anything in settings
ok, what apps do you have enabled
I didnt enable any app on my own, Only the default app should be enabled
@sturtz_nate where you able to find the issue ?
it would be really helpful if you can help me to solve this issue.
could you please post your full nextcloud log? it is /your/nextcloud/data-dir/nextcloud.log and your config.php file please remove all sensitive data
If you could
post it using ``` that would be nice```
sure, but i am new to this… should i have to ssh to the server and download the log or i can find it in the nextcloud dashboard ?
ssh into your server and do this cat /data/path/nextcloud.log
copy and paste that into here then cat /nextcloud/path/config/config.php
copy and paste this to
