How to fix a translation ?
I am the maintainer of the Souvenirs application, and I would like to either:
  • exclude the application name from any translation in any language
  • Fix a bad translation (in my case the german translation of “Souvenirs”, since it’s the name of the app, shouldn’t be translated)
I have a user that reported this issue : Support localization · Issue #5 · zorgluf/souvenirs-nextcloud · GitHub
Thanks in advance for your advices.
Best regards,
François
Hello @Francois_V :waving_hand: ,
Not possible as the xml from app store file is getting extracted.
Just added a comment to string at Transifex.
Adapted named string seconds ago.
Cheers
