I created a project to test the function. Is there a way to delete it? (Sorry if this should be obvious)
Which app are you referring to?
ToDo? Or Deck?
I was in the files app.
The reason I was testing the project functionality was that I was looking for another function that I couldn’t find anywhere else in Nextcloud. Specifically, I was looking for a way to create a folder which contains links to other files. The simple use case is a photographer has a folder with all of his photos and wants to create subfolders that can be shared that contain links to some of those photos. The idea would be that the files don’t have to be duplicated.
I just ran in to the same issue, I unshared the folder and that deleted the project.
