I don’t find any way to create a new project.
i expected an icon in the header.
in the Deck app i have an option to add some card or deck to a project, but NO WAY TO CREATE ONE.
my config:
snap nextcloud 18.0.4
Ubuntu 18.04.4 LTS bionic
PHP Version : 7.3.18
yes, it’s a little confusing. It is sufficient to assign the card to an object (map, board, file, …). Then a project with the name of the object is automatically created. with the name og the target, but you can rename the new project
