I’m trying to debug whether my Collabora server is running as it should. The Docker container seems OK(?). Is there a way from the command line, even a curl request, to confirm that the server is indeed running properly?
Also, where does Nextcloud store the Collabora URL? In the database? Or in a config file? I want to confirm that this is indeed being written. Even though I’m seeing it in the input field, I wanna be sure because I’m seeing errors again (PHP Fatal error: Cannot declare class GuzzleHttp) same as when it was empty.
# Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request GET /hosting/discovery.
Reason: **Error reading from remote server**
Apache/2.4.18 (Ubuntu) Server at my-server-address.net Port 443
So I guess I need to debug the apache virtual host config first.
