I’m using the Nextcloud Android library to add Nextcloud support to an android app using Android Studio. I’m having trouble configuring Proguard. When I run with minifyEnabled false all is fine, but with minifyEnabled true I get lots of Proguard related warnings and error. For example:
com.owncloud.android.lib.common.ExternalLink$$Parcelable: can’t find superclass or interface org.parceler.ParcelWrapper
library class org.apache.commons.codec.binary.BinaryCodec extends or implements program class org.apache.commons.codec.BinaryDecoder
org.apache.jackrabbit.webdav.server.AbstractWebdavServlet: can’t find referenced method ‘int getContentLength()’ in program class org.apache.jackrabbit.webdav.WebdavRequest
I can run with disabling the warings , for example
-dontwarn com.owncloud.android.lib.**
etc.
But then the app crashes as soon as a client completes.
I have tried copying the Proguard.cfg settings from the Nextcloud client app on Github, but that does not make a difference.
Any idea how to configure Proguard to make this work?
Thanks in advance,
