I have installed Docker CMS on NC13 (with OnlyOffice) with docker and nginx. The default installation propose these changes in the Apache configuration.
Using MOD_PROXY:
ProxyPass /sites/ http://cloud.mydomain.com/index.php/apps/cms_pico/pico/
ProxyPassReverse /sites/ http://cloud.mydomain.com/index.php/apps/cms_pico/pico/
Using MOD_REWRITE:
http://cloud.mydomain.com/index.php/apps/cms_pico/pico/example/
RewriteEngine On
RewriteRule /sites/(.*) http://cloud.mydomain.com/index.php/apps/cms_pico/pico/$1 [QSA,L]
Using MOD_REWRITE och MOD_PROXY:
http://cloud.mydomain.com/sites/example/
RewriteEngine On
RewriteRule /sites/(.*) http://cloud.mydomain.com/index.php/apps/cms_pico/pico/$1 [P]
I have tried one solution for nginx proposed here https://github.com/nextcloud/cms_pico/issues/24
location /sites/ {
rewrite /sites/(.*) /apps/cms_pico/pico/$1 break;
proxy_redirect off;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_pass https://sub.domain.tld/;
but I could not get it working
I am a bit confused at the maptree does not look the same in my set up as in the examples above.
I have 2 pico folders (one pico and one Pico).
/var/lib/docker/volumes/dockeronlyofficeowncloud_app_data/_data/custom_apps/cms_pico/vendor/picocms/pico
/var/lib/docker/volumes/dockeronlyofficeowncloud_app_data/_data/custom_apps/cms_pico/Pico
I need help to set up the nginx configuration.
