Does anyone have a working example for how to block certain folders from been accessed via a mapped webdav drive?
For example we have a group folder called “Directors” but when I map my webdav files access on a specific computer I would like that folder to be inaccessible since others will use it also and its too easy for me to forgot or leave the mapping there.
I think it should be possible using a Flow ‘block access to a file’ feature and probably a regex expression on request URL, but I’m not good with regex.
Can anyone help?
