Due to my lack of understanding, I appear to be going the wrong way about doing something that may be relatively easy to most and hope somebody can help.
I have NC 19.04 (SNAP) installed on an Intel NUC with 128Gb SSD and a 2Tb external USB HDD (This is recognised by Ubuntu and I have created a simple folder on it).
All I am trying to do is make that folder available to any account that uses the NC as a start.
lsblk lists the drive as sbd2
Could anybody please let me know the steps needed to add the drive and folder
You need to set it up as external storage. Assuming you have already formatted and mounted this disk, you can configure it as SFTP external storage even though it’s on the same server. I’m not sure if the “local” external storage option works with snap.
If you want it available to all users, go to Settings > Administration > External Storage.
I have a RPI4 where I installed NextcloudPi via Portainer with this docker image.
The application is working and I’m now trying to add a HDD external storage. I installed the external storage app on nextcloud and I want to set a Local connection to my HDD Seagate Expansion Drive 4TB.
