Hi, I have an application and I want to add some new Contacts to the contact app by using IManager->createOrUpdate method. Byt I want to set the type of properties too. for example, I want to Add a Phone No with HOME type and also another phone number with Work type. but I could not find any code example or hint to do this. can Anybody help me with this subject?
$contact = [
'FN' => $name,
'EMAIL' => [
'type' => 'HOME',
'value' => 'user@domain.tld',
$contactsManager->createOrUpdate($contact, $addressbook);
that is some code I found for contact emails. I guess you can use the same schema for phone numbers.
It did not work and it create some comma-separated value inside that field.
i see. then you will have to step through this with a debugger.
