Hi everyone,
I’m reviewing my Nextcloud configuration and came across this option:
PHP
‘enable_chunking’ => true
Mostrar más líneas
I understand it’s used to upload large files in chunks, which should help with slow or unstable connections. My questions are:
How recommended is it to keep this option enabled?
Has anyone experienced issues with chunking (e.g., problems merging chunks, file corruption, etc.)?
Are there scenarios where disabling it is better?
Thanks for sharing your experiences and advice!
Hey @jhon2323 welcome back
the following notes are from our wiki: Improve upload performance · nextcloud-snap/nextcloud-snap Wiki · GitHub and might give you some insight regardless of your installation method.
see also Chunked file upload — Nextcloud latest Developer Manual latest documentation
our chunk size is set to 20MiB because we regularly transfer large database files (bak & trn) and found that 20MiB chunk size is optimal.
jtr
3
There is no such server-side configuration value. If it’s in your config, this isn’t doing anything.
system
Closed
4
