Hello everybody,
I test Nextcloud v11, with plan to update our v10, but i’ve got a strange problem.
I can upload file without restriction of size. I set the max upload size in settings to 1G, but i can upload file about 6g, with no warning.
How can i set a max size for uploading in V11?
Thank you for the response, but what i want is to set a maximum size for uploaded files through the web interface, this settings work with nextcloud v10, but don’t work anymore with Nextcloud v11.
I’m seeing the same thing with the preconfigured techandme VM.
The out of the box config is set to 1GB, but I’m able to upload 3GB and 4GB files via the web interface.
