Hoster creates folders for logging. How to ignore them in integrity check?
Hi, I have a new domain set up that I want to use exclusively for Nextcloud. So obviously Nextcloud should be in the domain root and not in some random sub folder.
However my hosting provider (all-inkl) is automatically creating two folders ("/logs" and ā€œ/usageā€) in the root directory associated with a domain. I can not redirect them. They always have to be there. The only possibility to get rid of them would be to disable logging all together. But for obvious reasons I do not want to do that.
After installing Nextcloud, it starts complaining about these extra files.
I now figured out that I could ā€œsolveā€ the problem by installing in a sub folder and redirect the root domain to this folder. It works, but I am not happy with it. It just looks ugly. Especially this thing with federated cloud. "myname@mycloud.com/n". Ugh.
I tried to rewrite URLs using .htaccess so that it can stay in the sub folder but looks like its in root. I failed. Maybe I am too dumb for it, maybe it is just not possible (tried 20+ variations and resigned because nothing was working).
Now considering if I should move it back to root and just disable logging. Also this might be a terrible idea. Having some IP-Logs might be important some day.
It all could be so easy if I could just tell the integrity check to ignore this two folders…
Any advise?
