Nextcloud version 14.0.1
Operating system and version Ubuntu 16.04
Apache 2.4.18 (ubuntu)
PHP version 7.0
The issue:
I have nextcloud installed on my local server with my local ip address. and then I try to use public address to my nextcloud with my isp public address. I’m using a router to setting port forwarding to forward public ip to nextcloud private ip address.
Some of my
Is this the first time you’ve seen this error? Y
keep loading after login (cannot upload file)
The output of your config.php file in /var/www/nextcloud/config/config.php
'instanceid' => 'xxxxxxx',
'passwordsalt' => 'xxxxxxxxxxxxxxxxxxxx',
'secret' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
0 => 'private_ip',
1 => 'public_ip',
'version' => '14.0.1.1',
'overwrite.cli.url' => 'http://private_ip/nextcloud',
'dbname' => 'xxxxxxxxx',
'dbhost' => 'localhost',
'dbtableprefix' => 'xxx',
'dbuser' => 'xxxxxx',
'dbpassword' => 'xxxxx',
[Fri Nov 16 10:57:27.138924 2018] [ssl:warn] [pid 71953] AH01909: 127.0.1.1:443:0 server certificate does NOT include an ID which matches the server name
[Fri Nov 16 10:57:27.141280 2018] [mpm_prefork:notice] [pid 71953] AH00163: Apache/2.4.18 (Ubuntu) OpenSSL/1.0.2g configured -- resuming normal operations
[Fri Nov 16 10:57:27.141299 2018] [core:notice] [pid 71953] AH00094: Command line: '/usr/sbin/apache2'
