i use the command “/occ upgrade --quiet --no-interaction” but i still get the output:
Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
Maintenance mode disabled
Why is this displayed although I use the “quiet” switch?
