Help with PR Process - Calendar Defaults
I logged a few PRs for an enhancement to Calendar, and while I’ve seen a few reviews assigned, there hasn’t been any activity. I realize that everybody is busy, but I wasn’t sure if I had failed to do a necessary step. If this is just one of those things that somebody will eventually get around to that’s fine, but if I did mess up and not do a necessary step, please let me know.
The PRs relate to being able to set more than one default reminder and the reminder type on a calendar.
(They are one change - it just requires implementation across three components.)
@rich0 welcome to the Nextcloud community :waving_hand:
you’ve made those PR’s in the right place, but the devs don’t usually hang out on the community forum!
recommend you comment directly on your PR’s.
the devs may be busy, but they’re always inclusive and very appreciative :hugs:
Hey!
Thank you for contributing code! Reviewing code takes some time. You can make it a bit easier by providing screenshots and perhaps a screencast of the feature in action. That way, designers can already take a look without having to build anything :slight_smile:
Thanks for the suggestion. I just added the UI screenshot here:
